96 e4od hard shifting od flash codes help!!!!
Old Aug 15, 2015 | 05:24 PM
farnorcal logger648's Avatar
farnorcal logger648
I have a 96 f250 powerstroke with an e4od auto. Truck has 308,000 very tough miles on it. Motor runs strong, but lately the Trans has been developing issues. It seems to go into limp mode, hard shifting with o/d light flashing, every time it hits a dirt road, which lately has been quite often as I drive it to work in the logging woods. That being said, I know the first response will be did you pull the codes? I tried to with an off the shelf obd2 scanner, which the truck has a plug in for under the dash. The scanner would not link up, however, and upon further inspection I found a tag under the hood stating it was an obd1 system. Now I'm lost. I don't know much about troubleshooting and diagnostic systems other than what Google could tell me and there seems to be some dispute about the model year and ca regulations? Help!!!!! Any info on how to retrieve the codes would be much appreciated
Old Aug 15, 2015 | 11:14 PM
Action4478's Avatar
Action4478
Look at the wiring from the vss to the frame closely . THe Vss is on the top of the rear axle . two wires .
Old Aug 16, 2015 | 07:22 AM
97-psd's Avatar
97-psd
also, you will need a code reader that can read CAN codes. Most off the shelf units will not be able to.
shawbran
Nov 13, 2024 12:53 PM
idi1993f350
16
May 12, 2017 08:33 AM
Rather be Strokin
Apr 15, 2015 10:03 PM
78Explorer
Jun 12, 2013 06:24 AM
bennyz351
Jul 1, 2011 07:07 PM
