2004 Chirping
Old Apr 7, 2019 | 11:13 AM
  #91
diesel_dan's Avatar
diesel_dan
Did you get the gasser for a good price? I like that you're keeping the 6.0 - he gets to "retire" now...
Old Apr 7, 2019 | 11:59 AM
  #92
coolfeet's Avatar
coolfeet
$3500 for gas van. Asking price was $4600. I explained the necessary repairs. Radiator tires and shocks. I have shocks and tires. $150 for the new radiator.
I pulled everything out of the way to get the radiator out of the 5.4. Radiator arrives Thursday.
Old Apr 8, 2019 | 07:59 PM
  #93
6point0's Avatar
6point0
I didnt read much of this post. My 6.0 had a squeal a few years ago couldn't figure it out, some how decided to check out the manifolds... passenger side one was JUST loose enough that the gasket was whistling,,, like a piece of grass between your fingers i guess,
Old Apr 8, 2019 | 11:40 PM
  #94
coolfeet's Avatar
coolfeet
The chirp follows a rhythm. I tightened the manifold bolts to correct torque.
Old Apr 9, 2019 | 11:57 AM
  #95
diesel_dan's Avatar
diesel_dan
I'm sure you've seen this, but just in case:
Home
Enjoy,
Scott
Old Apr 9, 2019 | 03:22 PM
  #96
coolfeet's Avatar
coolfeet
Home
Enjoy,
Scott
I like going back to that million-mile van! His maintenance plan was hap-hazard at best!
Old Apr 9, 2019 | 04:19 PM
  #97
diesel_dan's Avatar
diesel_dan
Pretty much the same motor as you have (with a million two hundred thousand less miles!). I've played around with oil weights in ours and I think a 10W base is too heavy - had pretty high consumption with a 10W 30 and pulled it out early. I think you'll be fine with 5w 30 or 5w 20. If you change it every 5K the motor is guaranteed to go over 2 million miles...
Old Apr 9, 2019 | 04:22 PM
  #98
TooManyToys.'s Avatar
TooManyToys.
I don't know if it will make 2M miles. Probably at 1M he'll be pulling it home with the 6.0 .......
Old Apr 9, 2019 | 04:25 PM
  #99
diesel_dan's Avatar
diesel_dan
I dunno Jack, these 2V modulars are pulling some incredible miles - we'll see who is pulling whom home...!
Old Apr 10, 2019 | 02:58 PM
  #100
coolfeet's Avatar
coolfeet
Expy = Expedition (see sig.). Since the manual calls for the plugs to be changed at 100K or so, it is possible they weren't - problems are plugs seizing and screw up threads removing, but I think that really was a 3V issue, the 2V was plug blow-out. In both cases anti-seize on the threads of the new plugs (lots of controversy here, but the high mile guys do it...). The 4R100 is a stout trans and you can drain the torque converter, so not much need for a flush. Switch it over to Mercon V if you get it (Maxlife is my choice).
Since your 6.0 is a known to you and you have the leak down (squeal), why do you need a second van? Don't trust number one anymore? Too much cost to run? Then switch... But you gotta' do all the camping mods still...
Can you enlighten me on MaxLife ATF? I am getting ready for the MARK K flush. Post the reply here or the Van Forum. I started that thread.
Old Apr 11, 2019 | 11:55 AM
  #101
diesel_dan's Avatar
diesel_dan
Is this for the new guy 4R100? or the TorqShift? imo, you don't need to flush the former and on the latter only if it has foul trans fluid in it. Our 4R100 had a drain for the Torque converter - so there isn't that much left to flush. But your question was on Maxlife: Folks have used this with success in the Torqshift. However it is also a full synthetic that can be used for Mercon V applications. I have been switching everything I own that calls for Dexron or Mercon V over to Maxlife (haven't done the 5R100 yet). Valvoline makes a conventional oil base stock Mercon V, but I'm going to use the synth fluid...
My $.02
Old Apr 11, 2019 | 12:09 PM
  #102
coolfeet's Avatar
coolfeet
My $.02
It's for the new 4R100 E350 5.4 van. What MaxLife formula are you using? Are you saying there is no need to flush the 4R100 as everything including the torque converter drains through the pan?
Old Apr 11, 2019 | 12:22 PM
  #103
diesel_dan's Avatar
diesel_dan
I think there is only one Maxlife ATF, but don't quote me: it's the Dex/Merc full synthetic. It is the one that is LV compatible, but also Merc V -- last time I was in Wallmart I bought enough to do a dump and fill on the 4R100, put it in the power steering. It is already in my older Toyota/Auto and PS which is a Dex guy, and works great.
There is a cover on the bell housing and you rotate the torque converter around 'til you get to the drain plug, that's how you drain the Torque Converter. You'll still have some fluid in the cooler and places in the Trans, but that is the bulk of it, there and the sump. I only did that and a trans filter at 20K or so, since then I do dump and fills (6qts) every 10-15K miles: red fluid out and red fluid in - Expy tows 80% of the time...
Old Apr 11, 2019 | 12:38 PM
  #104
coolfeet's Avatar
coolfeet
According to Mark K "At this point, you can drain the torque converter. Some people think it is necessary, but I don't. Running the engine in the next steps will pump the fluid out of the torque converter."
Old Apr 11, 2019 | 12:53 PM
  #105
diesel_dan's Avatar
diesel_dan
If you just Have to do a flush, then do it! Ford had both procedures: drain torque converter and sump gets most of the old fluid out, or you can flush. If your trans fluid is dark then do a flush and get that last quart... Somewhere around '02 they stopped putting drains in the Torque converters, that's when flushing really became, ahhh, necessary. Some folks get very AR about every drop of old fluid out, to each his own...
Best of luck...
Scott
