Anyone have the battery light turn on and off after you replace both batteries and the alternator? It will flash on and off for about 15 mins of the drive then turn off until the next time we drive it. Any ideas would be appreciated
Maybe plug a battery monitor into the power point to see what the numbers are doing.
The 3 pin connection to the alt can have a bad connection until it warms up and this will cause the light to go on. Grounds are important as well.
I also had a huge issue with the rectifier in mine. Kept going bad. I put another brand alt on and have not had an issue since. Along with the new alt, I wired a power and ground directly to the battery. This helped a great deal.
Most likely culprit is the connector that plug into the back of the alternator.
the prongs get bent taking it off, either bend them back so they grip tight or spend a few buck and replace the connector with a new pig tail from any auto parts store.
