Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2009 Escape Battery Light problem
Old Oct 6, 2014 | 08:32 PM
GRNMSTR's Avatar
GRNMSTR
I have a 2009 Ford Escape Limited with 3.0L. When Idling the Battery Light will turn on and stay on and when driving above 45Mph the light will turn off and then turn back on several miles down the road. After taking the car to Autozone and having the Alternator and Battery checked, I was told that the Voltage Regulator was bad and that I had to replace the Alternator due to the Voltage Regulator is not a serviceable part. After replacing the Alternator the battery and charging system is reading 13.86v (steadily) and when idling for about 5 minutes the Battery Light will come back on. I drive about 200 miles daily and do not want to get stranded... Any suggestions as to what else could be the problem?
Old Oct 6, 2014 | 08:41 PM
JWC 3's Avatar
JWC 3
Have your battery properly tested . A faulty battery can cause this type of issue . Go to a reputable shop for a proper diagnosis . Do not trust fast food drop outs to diagnose your vehicle .
Old Oct 6, 2014 | 08:43 PM
wptski's Avatar
wptski
Actually 13.86V is a bit low. I believe it should be over 14V.
Old Oct 8, 2014 | 06:42 PM
GRNMSTR's Avatar
GRNMSTR
I took it to NAPA today and they tested the Alternator and the Battery both passed and the Alternator is generating 14.28v and the CCA of the battery passed at 700CCA. Any other Ideas????
Old Oct 8, 2014 | 06:44 PM
GRNMSTR's Avatar
GRNMSTR
The Battery light is now staying on, except when first started the light will come back on after a few minutes and stay on....
Old Oct 8, 2014 | 07:05 PM
JWC 3's Avatar
JWC 3
You need a Shop, Dealer or independent . Not a parts house .
Old Oct 9, 2014 | 08:55 AM
FordService's Avatar
FordService
Official Ford Rep
How many miles are on your Escape, GRNMSTR? It might be time to get this in front of your dealership. Keep us in the loop.
Crystal
Insane451
Apr 3, 2014 11:05 AM
medic25
Dec 10, 2012 02:20 PM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
Phil056
May 12, 2004 04:16 PM
dsring72
Electrical Systems/Wiring
Apr 16, 2003 10:09 PM
