Battery Light
Old Aug 30, 2013 | 11:52 PM
bebeard's Avatar
bebeard
Battery Light
Hi all, I have a 2004 F250, running great.... but some days my battery light comes on and stays on when I start the truck. I will drive a couple of blocks and it will turn off... What causes this and should I be concerned?
Thanks,
Old Aug 31, 2013 | 12:05 AM
BLADE35's Avatar
BLADE35
Sounds like your alternator is on its way Out
Maybe Batts
Get a Cheap Battery Hydrometer and check the Batts Cells Each one
what volts does the alt kick out??
Old Aug 31, 2013 | 12:27 AM
BLADE35's Avatar
BLADE35
ALTERNATOR CHARGING TEST FORD
http://api.viglink.com/api/click?for...13434327170573
Have a DVM At least??
Old Aug 31, 2013 | 12:41 AM
bebeard's Avatar
bebeard
I just replaced my batteries less than 6 months ago, I guess I will go and have my alternator tested.
Thanks!
Old Aug 31, 2013 | 12:42 AM
bebeard's Avatar
bebeard
Battery Light
What is DVM??
Old Aug 31, 2013 | 12:54 AM
BLADE35's Avatar
BLADE35
This
You Really need to check your FICM Main Power
Oh and Still Hydrotest them Batterys Cells
Its Cheap and Accurite
I use one like this Very Accurite
Old Aug 31, 2013 | 09:09 PM
bebeard's Avatar
bebeard
ok... had my batteries, starter and alternator checked today .... All good!
Old Aug 31, 2013 | 09:29 PM
BLADE35's Avatar
BLADE35
I hate to say it but that Battery Light Has Proven to be Very Accurite
Is the Bat Light staying Off???
Maybe a Loose Wire got Played with and tightened Better connection??
Old Aug 31, 2013 | 09:33 PM
BLADE35's Avatar
BLADE35
The Deal is the Battery Light kicks On when there is High system Demand right at Cold STartup when Glow Plugs are all On
The Bat Light coming on at Start likely means its weak or getting a Bad Alternator Diode
Do you have anything to watch Volts with??
You have to make shure that your charging system is at 110% or it will KILL the FICM FAST!!
Cheack All Wires Clean them and Smear Vasiline on them Follow the Main Grounds to where they Mount clean there
Sometimes its Cheap Easy Fix Too
You will notice most of the regulars have Upgraded Batterys CCA and went to High Output Alternators with Good Success
Old Aug 31, 2013 | 10:04 PM
04badford's Avatar
04badford
Great Advise Benny, also the batterie cable it self can be corroded at the connection and or Ground.
Old Aug 31, 2013 | 11:22 PM
BLADE35's Avatar
BLADE35
Yes Sir^^^Definatly check the Easy Stuff I seen a Bad ground cable or two cause this Bat Light
I spent an hour a Year or two ago with a Dremal tool cleaning all the Grounds and Battery Cable connections Put Vasaline or Grease on them and They stay Corrosion free
virgil spells
General Diesel Discussion
Sep 7, 2013 12:06 PM
medic25
Dec 10, 2012 02:20 PM
erik_bishop
Feb 18, 2011 11:05 AM
npccpartsman
Escape & Escape Hybrid
13
Jan 10, 2011 09:08 AM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
