hello. I have a 66 f100 352 3 speed 2wd. transmission. This 4 speed came up for sale. Owner said it is out of a f350 2wd. Will this trans work? Can I use my current Bellhousing? Thanks
That looks like a T-19 but could be a T-18. I put a T-19 in my '66 3-speed. It fit the bell and clutch. I switched the trans mount end for end, cut out the floor and scrounged a driveshaft.
Just following up on what Eric mentioned, here's a sample NP435 top with the reverse switch built in - the little red connector on the side. You swap this in and you can have easy backup light connector. All it does is ground the circuit to complete it.
ND my 66 has a 435 and no reverse switch. Would be nice if it did.
The reason why is, backup lights were not mandated by the US Gov't on all series' of trucks, Bronco's and Econolines until the 1967 models were introduced (September 1966).
US Gov't said that Passenger Cars had to have standard equipment backup lamps beginning 1/1/1966.
