New process 435
Old Nov 18, 2017 | 12:13 PM
mrpotatohead's Avatar
mrpotatohead
New process 435
Does anyone know why a N.P. 435 from a 71 wouldn't fit a 66 model truck both with FE engines?
Old Nov 18, 2017 | 04:44 PM
6t6merc's Avatar
6t6merc
It is the bell that matters. Do the bells have the same depth, (transmission side) bolt pattern, and housing bore diameter?
Old Nov 18, 2017 | 06:04 PM
garbz2's Avatar
garbz2
Bore changed in 71
66 to 70 bore is 5.125
71 to 87 is 4.848
You need the later bell housing with the smaller bore.
Garbz
Old Nov 18, 2017 | 06:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different FE bell housings, doesn't matter if it's a 3 M/T; 3 M/T with O/D (F100); T-18/NP435 4 M/T
#1) 1965 F100/250 4WD; 1965/66 F350; 1966 F250 4WD: These trucks use the same engine mounting system as 1961/64 292.
#2) 1965/66 F100/250 2WD; 1966 F100 4WD; 1967/76 F100/250 2WD/4WD & F350.
Old Nov 18, 2017 | 07:05 PM
85e150's Avatar
85e150
I couldn't find any reference to the bearing retainer o/s diameter until I found this:
https://www.ford-trucks.com/forums/6...-diameter.html
Old Nov 18, 2017 | 07:32 PM
mrpotatohead
Thanks guys, my 66 had no trans when I bought it. Someone robbed it before me. I found one advertised out of a 71 for 100.00. As long as I can make it work by changing bellhousings or bearing retainers it sounds like it's a good purchase.
Old Nov 18, 2017 | 07:37 PM
NumberDummy
1965/79: Three different NP435 front bearing retainers.
See 7050 along with the specs in pic from 1964/72 catalog. 1977: Ford replaced C5TZ-7050-A with D7TZ-7050-A
Old Nov 19, 2017 | 07:53 PM
mrpotatohead
Well I bought that trans. Gave him 50.00 for it. The tag says it came from a 78 however.
D8TA-7003 KB FF 3
10-9-78 2 435
Can anyone decode this?
Old Nov 20, 2017 | 09:25 AM
66v8baby's Avatar
66v8baby
Originally Posted by garbz2
Bore changed in 71
71 to 87 is 4.848
Garbz
Not true. All of the 2WD NP 435s in the 65/66 F100/F250 had the 4.849 outside diameter bearing retainer. I didn't check the 4WD PNs but I suspect they are also 4.849.
Old Nov 20, 2017 | 09:43 AM
TA455HO's Avatar
TA455HO
Lead Gopher
If you look at the list that ND posted it gives the diameter for the 4WD trucks as 5.125" (3rd part number from top), however you can use a reducer to bring it from that size down to one of 2 possible other sizes with something like this. Likely others out there, too.
716041 : Bellhousing Index Reducer Bushing | Advance Adapters
Chad
Old Nov 20, 2017 | 10:07 AM
NumberDummy
D8TA-7003 KB FF 3
10-9-78 2 435
Decode doesn't give you any additional info than what you already know.
Old Nov 20, 2017 | 04:14 PM
mrpotatohead
Thanks just the same sir number dummy.
VTrob66
Jun 24, 2018 06:07 PM
jas88
Feb 20, 2017 01:47 PM
SATpilot
Aug 13, 2013 09:55 PM
Pickupmanx2
Feb 11, 2013 12:09 PM
fordguy76
Jul 4, 2005 08:53 AM
