Fender Replacement Tips?
Old Mar 15, 2019 | 06:29 AM
CJ06SLT's Avatar
CJ06SLT
Question Fender Replacement Tips?
I'm working on replacing my very beat up front fenders on my '66 with a pair off of another truck. Does anyone know of a guide or have any tips on the process of getting these to fit correctly? If I just put them on and bolt on, the gaps are all wrong and the doors are a little too close for comfort. Just looking for the recommended process before I reinvent the wheel on these.
Thanks!
Old Mar 15, 2019 | 07:34 AM
wauto's Avatar
wauto
If your cab mounts and radiator support are good, start all bolts and leave loose. Then tighten the bolts to the cab first, assuring door gaps are correct. Then work your way towards the front.
Old Mar 15, 2019 | 11:13 AM
resonateur's Avatar
resonateur
...also, make sure the doors fit the cab first, and they are not sagging. Most of the mounting holes in the fender/apron are slotted to allow a little play. You can always elongate the slots if you need more adjustment. Everything else is somewhat “flexible” towards the front. As wauto said, keep all the bolts loose so you can push, pull, pry and tug to get the alignment you need before snugging the fasteners.
Old Mar 15, 2019 | 12:02 PM
dubya TF's Avatar
dubya TF
I believe your inner fenders actually have a tiny bit of side to side adjustability on the firewall too.
Old Mar 15, 2019 | 01:46 PM
SixtyFour's Avatar
SixtyFour
Are there any how-to's on dealing with door sag? When i open my passenger door and it unlatches the door drops/sags a bit. Unsure if there are worn parts or some of the hardware just needs to be snugged with the door in proper position. Or is it also a combo of worn out body mounts?
Old Mar 15, 2019 | 02:00 PM
dubya TF's Avatar
dubya TF
I don't know of any how-to other than just trial and error. If that door drops, I'd recommend checking how much flex the body mounts show, lift up on the door and feel how much play the hinges have and go from there. You can get replacement hinges or replace the bushings on your originals.
Old Mar 15, 2019 | 02:29 PM
CJ06SLT's Avatar
CJ06SLT
The doors look good to me, I don't think they've ever been off either. I'll look for play in them though. My main problem seems to be that the fender doesn't go in enough, and it is proud of the door. I'll try to get a pic or two when I get home tonight. Is there typically much metal shaping required when retrofitting?
Old Mar 15, 2019 | 03:24 PM
Christmas's Avatar
Christmas
The manual I have does not go into great detail. I agree that the doors are to be aligned after,
Old Mar 15, 2019 | 08:41 PM
resonateur's Avatar
resonateur
You can move the front of the door out by adjusting the hinges at the pillar. I would remove the striker and make my door adjustments first, the reinstall the striker for proper latching. If you move the door out, however, your weatherstrip may no longer seal. You can only move the fender inboard so much, as the rocker panel nut and the nut behind the kick panel, limit travel. Unless someone here has additional tricks short of major modification. Another issue is installing fenders that are not original to the truck. On the assembly line, close was close enough. Aaaaahhhhhh, the pleasure of working on older vehicles!
Old Mar 16, 2019 | 02:17 AM
yargnitram's Avatar
yargnitram
is that body manual available,does anyone do a copy/pdf
Old Mar 16, 2019 | 09:37 AM
Christmas's Avatar
Christmas
https://www.ebay.com/itm/1965-Ford-T...432f%7Ciid%3A1
Old Mar 16, 2019 | 02:36 PM
James_Western_Canada's Avatar
Those assembly manuals are available directly from Jim Osborn reproductions for $25.00 + shipping
$69 + shipping is nothing short of EXORBITANT
Product List
James
Old Mar 16, 2019 | 05:02 PM
Christmas's Avatar
Christmas
my bad for pickin the most $$$$$$$$$$$$$
https://www.ebay.com/itm/1965-Ford-T...IAAOSwG-1Wu9o~
Dave Kapp
Aug 18, 2008 09:45 AM
Hakk
Jan 11, 2008 12:15 PM
EDMist
Jun 17, 2007 07:08 PM
AK Fifty-Three
Feb 19, 2006 10:15 AM
joners
Dec 1, 2003 05:45 PM
