Sponsored by: Auxito
One piece rear window gasket
Old Sep 30, 2003 | 08:41 PM
triton_2002's Avatar
triton_2002
Question One piece rear window gasket
I have a 02 F-150 supercab with the one piece rear window. There is a black plastic trim around the window and in some place the rubber gasket underneath seems to be squeezing out. Does anybody else have this problem? I've never had any water leaks but it looks like a problem waiting to happen.
Old Sep 30, 2003 | 11:41 PM
Racerguy's Avatar
Racerguy
I havent seen this happen but even if it does leak it isnt a really big job to remove the window and reseal it.
Old Oct 1, 2003 | 05:48 PM
triton_2002
How does the rear window attach, anyway? It looks like its just pressed on. Are there some kind of fasteners under that trim?
Old Oct 1, 2003 | 08:06 PM
Racerguy's Avatar
Racerguy
There are nuts behind the interior trim. You remove the interior trim around the inside of the back window to get at them.
Old Oct 1, 2003 | 11:12 PM
BigA_02's Avatar
BigA_02
i have a slider and the gasketis squeezed out but mine does leak. how hard i ti to pull out the window and seal it/
Old Dec 30, 2003 | 09:16 PM
Fat Ford Boy's Avatar
Fat Ford Boy
We have that same problem, (with the "oozing", on our 2001, and on our 2002 King Ranch).
Ford told us on the 2001 that it has to be reported, and they "try" to put back in, and then if that don't work, they replace it, but won't guarantee that it won't happen again.
Old Jan 3, 2004 | 08:18 AM
derek7871's Avatar
derek7871
I had the same problem on my 2001 with a sliding rear glass. The gasket was pushing out and in a hard rain it would leak. I took it to the local Ford dealership thinking they could just replace the gasket. Turns out the only fix is to replace the entire glass. It was under warranty, so no big deal for me. If your truck is still under warranty, get it fixed now.
Old Jan 3, 2004 | 11:11 AM
ck1404's Avatar
ck1404
It is my understanding the solild rear windows will not leak with this gasket displacing itself - the rear sliders are likely to leak. In the case of my 1999 F-150, the problem started early on. I took it to the dealer - who I have trusted for many years and still do - and was told that Ford would pay to replace the gasket. But, I was also told that it was likely to do it again and that in the case of the solid rear glass as in my truck - it definitely would not leak. I discussed the process of removing that glass to replace the gasket and was told it was not all that easy. Mine was complicated with the fact that I have a shell on the truck. I decided to leave it like it was, that was four years ago and it has never leaked. Rather than the gasket oozing out (as in the case with our 2001 F-150), my 1999 model had the gasket falling down inside the window frame. I imagine Ford changed the design so that rather than the gasket disappearing within the window, it fits tighter and usually tries to squeeze itself out. If it is a solid rear window, I don't think it will leak. Since the gasket on my 1999 model literally disappeared within the window frame, I usually don't even think about it anymore - out of sight, out of mind. In the case with the 2001 model, I just push it back in when I see it squeezing itself out. Neither truck has ever leaked.
Old Jan 4, 2004 | 09:46 AM
TooTired's Avatar
TooTired
I noticed on my 2002 that where the two ends of the gasket meet, they were starting to come apart. There is like a 2" gap and i figured the ends of the gasket should but up against each other. So I drove to a couple of ford dealers to look at the new and used f150's on the lot to see if they were the same. To my surprise very few even had the black rubber gasket. It almost appears that they shrivel away and fall in behind the window. Out of 10 trucks I would have to say I only saw 1 or 2 with the gasket still in place. Mine does not leak, so I have not brought it to the dealers attention as of yet.
Old Jan 4, 2004 | 10:03 AM
pro3qtr's Avatar
pro3qtr
Re: One piece rear window gasket
The black plastic trim is nothing but trim.
Has nothing to do with the window itself.
I know, I replaced my Factory slider with a aftermarket steel frame version.
Gasket is just a aerodynamic seal, thats all.
Old Mar 8, 2004 | 08:25 AM
glockfixer's Avatar
glockfixer
I'm having the same problem with my '97 supercab. The top of the gasket between the body and trim has a low spot where water is getting in. I bought mine used so I think I am in for a fight with the dealer. We will see..............
Old Mar 8, 2004 | 10:28 AM
d0n_3d's Avatar
d0n_3d
my back sliding window leaks like CRAZY when it rains...how much does it cost normally to have it fixed???
Old Jan 20, 2009 | 08:52 AM
even7steven's Avatar
even7steven
my 99 L is leaking just above the drivers seat. i found this article and i'm going to try to fix it myself before the next big shower:
http://www.2carpros.com/forum/2001-f...-vt211998.html
tkjoe508
Oct 21, 2016 09:30 AM
jthorngate3
Jul 12, 2015 01:50 PM
Dogmann
Aug 23, 2014 09:56 AM
Diesel_Brad
Jul 10, 2010 11:52 AM
3DALE8
1983 - 2012 Ranger & B-Series
Dec 24, 2004 10:07 PM
