Vacuum Wiper testing
Old Mar 10, 2019 | 09:34 PM
Harrier's Avatar
Harrier
Since I have the interior of my truck torn apart, I figured I would pull the vacuum wiper motor and clean it all up and see if I can get the wipers working.
I will start off with a question. Does anyone know if you can get the metal rod that connects the control assembly with the ****? The parts book has that all as one piece.
For some reason I thought I had a **** that had a metal piece sticking out of it somewhere. I hope I didn't throw it away years ago.....
I found one cable on ebay for $109, not sure I need it that bad.
For anyone looking, it is part #BAAA17470A
I got the wiper motor out and I will bench test it soon. I saw a video where someone just hooked a shop vac up to it and moved the switch....
Also, anyone have tips on how to get the wiper arm off? I don't know that I need to, but it would be helpful if I need to re-position them when I get the motor back in and running.
As little as I drive it and only in the rain if I get stuck out in it. Rain-X may be a good solution as well.
Another thread mentioned Fickin Wiper Service and said they do a great job of rebuilding these....
Boy these trucks are easy to tear apart.......
Old Mar 10, 2019 | 09:51 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Joe, those things show up on E-Bay every few weeks it seems. Prices are all over the map with some at giveaway and some like you saw for high bucks. Even whole motor assemblies with the rod show up. I was looking for dual-wiper connector linkage and keep seeing those parts you are looking for instead.
I just went through my spare parts and found I have a **** & cable that I won't be using. It's in good shape, and 24" long. Moves freely and the **** is in good shape. I'll send it to you if you can use it.
Tom
<edit> Sometimes the wiper arm gets stuck on the knurled shaft due to corrosion. You have to warm it up, pry a bit, chase around the lip in circles and continue to tap and pry it off. I found it best to not clean the knurl like crazy if you get it off, or it will fit too loose when re-assembly happens.
<double-edit> My cable is for a '48 to '50 and although the **** end looks like yours, I see some differences.
Old Mar 10, 2019 | 10:22 PM
abe's Avatar
abe
I know nothing about vacuum wipers, except they don't wipe when you are accelerating, since both my Standard Cab trucks have he optional electric wipers.
But Joe, I had trouble getting the wipers off of my 55. So I went to my local family owned garage. Steve, the youngest of the brothers said, "My Dad (who is deceased) has a tool that will get it off." It was a Trico slide hammer with a two pronged claw. A few slides of the hammer and it was off.
Old Mar 11, 2019 | 04:06 AM
leonharu's Avatar
leonharu
Send the motor to Ficken Wiper Service for rebuild while you have it out.
Old Mar 11, 2019 | 06:25 AM
Harrier's Avatar
Harrier
I will give Ficken a call today and see what he has to say.
Tom, do you have a picture of your cable. They have different part numbers.It's a straight forward part, so I wonder why they changed them. Maybe the motor is a bit different?
Old Mar 11, 2019 | 06:34 AM
leonharu's Avatar
leonharu
If you can't reach him by calling you can email him (sales@wiperman.com).
Old Mar 11, 2019 | 08:07 AM
fordf348's Avatar
fordf348
Ficken rebuilt mine about 4 years ago, it works like new, maybe better than new. I cant remember that far back.
Ed
near Philadelphia
Old Mar 11, 2019 | 04:31 PM
pineconeford
Originally Posted by Harrier
...Tom, do you have a picture of your cable. ...
Here it is.
For size perspective, the cable has a 1965 quarter that I found in the dead hole of the back of the cab of my truck when I removed the seat.
The cable is 24" long.
Tom
Old Mar 11, 2019 | 05:43 PM
rusty48's Avatar
rusty48
I just put mine back in and did not get a photo, Wound not move at all, tried a little ATF in the port., swished around, let it sit overnite and it had vacuum. put a brake bleed on and it worked like a charm. Sometimes you get lucky.
Mine did not appear quite as crusty as yours however.
Old Mar 11, 2019 | 06:45 PM
leonharu's Avatar
leonharu
Does anyone have a diagram or picture of an original routing of the cable from switch to motor on 1952 F-1 vacuum wiper.I got mine apart and did not take any photos before??
Old Mar 11, 2019 | 07:58 PM
Harrier's Avatar
Harrier
I just messaged back and forth with Ray and he has a motor, but it looks like it won't work. The connector to the wiper arms are different.
Tom's cable might work. Since a photo has to be on the web to private message. Tom, does this look like the end of your cable?
You can post in a thread then put in a private message It's good to show this end to everyone though.
Old Mar 11, 2019 | 08:09 PM
Harrier's Avatar
Harrier
For reference, here is an older vacuum wiper motor.
The wing nut type of thing is where the wiper arms attach.
Old Mar 11, 2019 | 08:11 PM
Harrier's Avatar
Harrier
And here is a cleaner picture of mine where the wiper arms attach.
I figure documenting this here will hopefully help others.
rswhitmore
Jan 10, 2015 07:26 PM
WingingIt74
Aug 27, 2014 09:10 PM
Rusting-Nuts
Nov 20, 2011 01:15 PM
leonharu
Nov 28, 2007 11:33 AM
atticmole
Mar 23, 2004 12:33 AM
