Can the Keyless Remote roll windows down?
Strangest thing happened yesterday. My truck was parked just outside of the mechanical room I was working in and at some point, I decided I better lock the doors in case I'm busy and someone spots my laptop on the console. So I pulled out my OEM ignition key/keyless entry remote and hit the lock button. A few minutes later I came out to the truck to get something and the two front windows were down all the way (and I know they were up before because I had just parked there and it was cold outside) and the doors were locked. The only thing I could think of is that the key was in my pocket and while working I accidentally hit some kind of crazy button combo that caused the truck to roll the windows down. Is this even possible? 2018 F350 SuperCab CC 6.2L XL
From the user manual
You can use the remote control to open the windows with the ignition off.
Note: To operate this feature, accessory delay must not be active.
Opening the Windows
You can only open the windows for a short time after you unlock your vehicle with the remote control. After you unlock your vehicle, press and hold the remote control unlock button to open the windows. Release the button once movement starts. Press the lock or unlock button to stop movement.
Opening the Windows
Opening the Windows
Opening the Windows
Some may be interested to know that you can enable remote-activated front window roll up using Forscan. When you hit the lock button on the remote, just hold it down for a few seconds and the windows will roll up.
That_Guy
08-15-2009 11:56 AM
fordiesel69
09-25-2008 09:50 PM
