Reprograming electronic door locks
Old Aug 15, 2009 | 08:55 AM
That_Guy's Avatar
That_Guy
Anyone know how to reprogram the unlock/lock on our trucks? I lost both of mine last fri...I know its in my owners manual but I cant seem to find mine
Old Aug 15, 2009 | 09:37 AM
King0581's Avatar
King0581
I remember seeing the guy at the stealership do it when I bought my truck but cant remember exactly what he did to save my azz. I think you have to turn the switch from off to run so many times with in so many seconds and hit a button on the remote but not sure.
Old Aug 15, 2009 | 09:46 AM
That_Guy's Avatar
That_Guy
Yup thats right, I just need to know how many times and what buttons to push lol
I tried for about 30 min last night with no luck.
Old Aug 15, 2009 | 09:54 AM
King0581's Avatar
King0581
Found this....
PROGRAM KEYLESS ENTRY/REMOTE
(Up to 4 units max)
(All locks must be up or down at start)
1. Insert a key in the ignition and turn from OFF to ON eight times in rapid succession (within 10 seconds) with the eighth turn ending in the ON position.
2. The doors will lock/unlock to confirm that the programming mode has been entered.
3. Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated).
4. Repeat step 3 to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
5. When you have completed programming the remote transmitters, turn the ignition to OFF or wait 20 seconds. The doors will lock/unlock to confirm programming has been completed.
Valet Mode: Insert a key in the ignition and turn from OFF to ON three times in rapid succession (disables anti-theft). To enable anti-theft, Insert a key in the ignition and turn from OFF to ON three times in rapid succession.
***NOTE: You have to program all the remotes every time. Only the remotes you program during that session are going to work with your truck, so make sure you program all the remotes you want to work each time!***
Old Aug 15, 2009 | 10:03 AM
That_Guy's Avatar
That_Guy
Thanks Lee, reps sent
Old Aug 15, 2009 | 11:56 AM
triskit16's Avatar
triskit16
Yep, thats it!
tkiner
2009 - 2014 F150
Jan 11, 2010 01:27 PM
Harvick
Apr 8, 2009 03:29 PM
cajunbull61
Apr 8, 2008 10:16 AM
esco24
May 27, 2007 07:36 PM
plb7732
Apr 3, 2006 10:01 PM
