I beams
Old Mar 8, 2019 | 09:21 AM
Dirky90's Avatar
Dirky90
I beams
The i beams on my 66 are bent. Would the i beams off a 73-79 fit. I want to switch to disc brakes so that would be a plus also.
Old Mar 8, 2019 | 11:53 AM
imacreep's Avatar
imacreep
I have swapped everything from a 1976 into my 1965. Bolt for bolt. Power steering, disk brakes & all bolt right up. If you can find a donor truck with the same engine, you'll need all kinds of brackets, bolts, proportion valve, booster & hard lines. I've never taken it in for an alignment after doing new ball joints, bushings and shocks. Drives perfectly straight!
Old Mar 8, 2019 | 03:24 PM
Dirky90's Avatar
Dirky90
Thanks for the quick reply. Went to the junkyard today. They had one 76 but someone had already pulled the i beams
Old Mar 8, 2019 | 03:32 PM
Christmas's Avatar
Christmas
This is a 79 F250 into a 66
Old Mar 8, 2019 | 03:50 PM
Dirky90's Avatar
Dirky90
Is there anyone in the myrtle beach sc area that has stock i beams for sale that fit drum brakes? Heres whats going on. Somewhere in the trucks history somebody cut the springs and c notched the front. Well when they bent the i beams the passenger side was bent more than the drivers side. So needless to say theres vibration. If i cant find stock beams then ill go ahead and get dream beams and do the whole deal. Just checking here first. This is my first time on the ford truck forums. Thanks
Old Mar 8, 2019 | 04:01 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Christmas, did you noticed anything different with the spindles? Mine on my drum brake truck look just like those.
Chad
Old Mar 8, 2019 | 04:04 PM
Christmas's Avatar
Christmas
The beams were meant to be bent. Usually for caster camber adjustment. Might want to try taking them off and use a press and try to straighten them back out.
Old Mar 8, 2019 | 04:23 PM
Dirky90's Avatar
Dirky90
They bent the drivers side good tires perfect. They must have started on the passenger side and figured it out on the drivers side. Its bent front to back not up and down. Its hard to explain but its definitely not right. Spindles look normal
Old Mar 8, 2019 | 04:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6TZ-3006-C Right & C6TZ-3007-C Left .. I-Beam / Obsolete
1965/70 F100/250 2WD // 1969/70 E100/200 // 1971 F100/250 2WD & E100/200 with I beam stamped with ID number: C8TA-3008-B (right) or C8TA-3009-B (left)
Old Mar 8, 2019 | 08:53 PM
john jamieson's Avatar
john jamieson
You might try calling a big truck tire shop and see if they can straighten them for you.
Old Mar 8, 2019 | 09:01 PM
Christmas's Avatar
Christmas
Chad, I don't know for sure but I think it has to do with how the external hardware mounts to them (backing plates, caliper carrier etrc)
Old Mar 9, 2019 | 05:47 AM
Crop Duster's Avatar
Crop Duster
I beams
Try this link http://www.car-part.com/index.htm
I'm sure someone close to you will have some. They don't list every part they have on here so you need to get creative and try different parts in order to find someone who has a truck you can get parts from. Also if you ever want a sway bar on the front try to find a 75-79 and get the radius arms with the I beams. The D5TZ-5C499-A sway bar brackets that match up to the radius arms are getting hard to find but are the same 75-79 F100 to 350 and 75-91 Econoline.
Well for some reason the link won't work so just type it in.
Old Mar 9, 2019 | 03:54 PM
Bert65's Avatar
Bert65
I have a pair of 78 beams and soon set of 65
I purchased 78 for disc conversion, then decided to use drop beams, so the spindles are not with 78, just beams
65 will have spindles attached for drum use.
i say soon for 65, because I have not pulled them yet, but plan to soon.
if anyone wants them, let me know
heavy, so shipping from Dallas TX area may not be cheap
it will only cost you shipping
I am sure pay it forward will come around to be at some point.
Old Mar 11, 2019 | 09:12 PM
hello113's Avatar
hello113
here is a almost complete setup with discs up already pulled in Arkansas / Texas for 300 on crags list
https://littlerock.craigslist.org/pt...811899604.html
don't know the feller but it might be worth a road trip
mike
10strokin
Nov 23, 2012 07:02 PM
Chris Clarkson
13
May 9, 2012 04:57 PM
leftturndave
Apr 18, 2010 11:11 PM
johncardi
17
Feb 17, 2010 04:15 PM
Daveo1
Aug 26, 1999 04:40 PM
