front disk brake swap
Strokin, Short answer yes. I bought a 76 donor, parked it beside my 66, dropped the I-beams from the 66, then the 76, slid them over and bolted them up under the 66. All bolt hole exchange. I also used the power steering from the donor, so you will need to find one with the same engine & tranny as you have or want to go to for pump & column install.
Buy your donor so you will have all the necessary parts needed.
John
John
Up to 79 I beams will bolt in.Also need proportion valve,brake booster and master cylinder.These are better to get the brake pedel also 78and 79 are different for the mounting hole are moved and the pedel sits low pretty close to the floor.I put a 77 set up in mine aswell as power steering.
BigDfromTN
06-28-2014 11:23 AM
Shadowrider123
05-16-2012 11:57 AM
CN Spots
09-24-2009 02:49 PM
winr
04-08-2008 08:59 AM
Wyatt66f100
09-17-2007 08:10 AM
