disc brake I beams
Old Apr 18, 2010 | 04:11 AM
leftturndave's Avatar
leftturndave
disc brake I beams
Hi. New guy to the forum.
I have a 65 f100 (twin I beam....)
Has anybody tried to install later, ball joint style i beams on an early truck ?
No too many king pin style trucks left around here for donor parts !
If it would work, then i might just have to buy a set of drop beams...
Dave
Old Apr 18, 2010 | 04:33 AM
jowilker's Avatar
jowilker
Dave I don't think a critter that you describe exists. 73-79 donor I-beams have the disc brakes needed, and you can swap dropped beams in when you do the upgrade.
Are you wanting dropped beams & power disc brakes??
John
Old Apr 18, 2010 | 04:57 AM
F&M's Avatar
F&M
Welcome also.I'm new here as well.This is great site and these guys are THE SHIZZ! I think you mean dropped spindles,and I looked all over and don't think anyone makes 'em.Just a thought:Would say an 18 or 20" wheel get a lowered effect? I know it won't really lower it but wouldn't is close the gap between the top of the tire and the bottom of the fender?
Old Apr 18, 2010 | 11:59 AM
leftturndave
disc brake I beams
Hi Joe..
What I am asking is if 80 and up I beams will fit ??
I am having no luck finding 72 to 79 I beams in this area, but there are several 83 and up. (That is what I meant by asking about BALL JOINT I beams )
Thanks
Dave
Old Apr 18, 2010 | 12:43 PM
66f-100's Avatar
66f-100
I wouldn't try to reinvent the wheel. Do what is easy and use 73-79 i-beams with disc brakes. It's a bolt up swap. It took me a while to find a suitable donor for the right price, but it was worth the wait. Try searching craig's list every day, something is bound to turn up sooner or later.
Mark
Old Apr 18, 2010 | 01:56 PM
santi2322's Avatar
santi2322
Dave- update your profile when you get a chance and put where you are located. A lot of times members in your area may have something but there is no way to know where you are right now. I just put the drop I-beams on my truck so I have some spare i-beams off of a '77 that I got with everything I bought. Welcome and good luck. Patience is needed on these trucks as you know by now that everything you need is not easily accessible. It will come your way eventually.
Old Apr 18, 2010 | 02:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The state (or country) where members live is listed.
Dave is located in CA.
Click on the members name, then View Public Profile. The info is listed in "About Me."
Old Apr 18, 2010 | 04:09 PM
leftturndave
I am in Castroville, CA ( monterey bay area )
Close to salinas, monterey, watsonville etc...
A good friend owns a big wrecking yard in watsonville. The problem is everything more than 10 or 12 years old gets crushed right away !
Dave
Old Apr 18, 2010 | 04:43 PM
brown79's Avatar
brown79
pick n pull in moss landing ca lists 3 trucks in their inventory that would work
Old Apr 18, 2010 | 07:56 PM
bigblockford_390's Avatar
bigblockford_390
Originally Posted by leftturndave
Hi Joe..
Thanks
Dave
If you take a look at your I-beams and same ones up to 1979 they attach to the frame on the oppistie side frame rail.
The 1980 and up attach to the middle of the cross member under the engine. You would have to do some major frame modification to put that style on, more work than it would be worth IMHO.
The 1973-1979 are a direct bolt on to your 65. I completed the swap a couple years ago and it is pretty straight forward. Lots of us have completed the swap and can help out where needed.
Jeff
Old Apr 18, 2010 | 11:11 PM
leftturndave
Thanks !
I rarely go to pick and pull because my friend in watsonville takes VERY good care of me price wise.
I will check p&p out tomorrow.
Dave
dwil
Arizona Chapter
Aug 17, 2014 09:27 AM
4INer
Feb 27, 2014 07:27 AM
V10man
Aug 22, 2012 03:47 PM
dstig1
May 31, 2008 06:51 PM
williamwilliam
Oct 3, 2003 04:46 PM
