Replacing Wheels and Speedo
Old Mar 7, 2019 | 11:27 AM
SJMaye's Avatar
SJMaye
Hi,
I have the 22" PVD wheel with lowish profile tires on my 2016. Both are original equipment. Ford has already 3 wheels under warranty for peeling chrome. My warranty has run out. I know they will peel again and I will have to replace these wheels. When this day comes I thought I might get a smaller diameter wheel and a taller sidewall tire in hopes it give a less harsh ride.
My question- I will try to keep the circumference of the new tire/wheel combo the same, but if it is not is there a setting that can be changed somewhere that will keep the speedo accurate?
Old Mar 7, 2019 | 04:27 PM
scott91370's Avatar
scott91370
Yes using Forscan. Or buying a dedicated unit. Or buying a tuner.
Old Mar 7, 2019 | 07:02 PM
msgtord's Avatar
msgtord
https://tiresize.com/calculator/
Old Mar 7, 2019 | 11:05 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Old Mar 7, 2019 | 11:50 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Originally Posted by SJMaye
Hi,
You can generally get a tire/wheel combination that is really really close to the same as what you are starting with, then avoid having to reprogram anything. We're exploring a little bit of this type of thing in: https://www.ford-trucks.com/forums/1...a-limited.html
Old Mar 8, 2019 | 05:28 AM
SJMaye's Avatar
SJMaye
So I take it from the responses that there is no hidden setting screen in my Sync 3 that allows you to alter the speedo readout based on the circumference of the tire. No problem. I see from your replies it should be too difficult to come up with a combination that will replicate my current setup.
May I ask?
I stated I found the ride "rough" or "harsh". I am comparing that with my 2002 F-150. I really liked the ride of that truck. There are two major aspects of this 2016 truck I can think that would make it ride rougher; lower tire sidewall height, max tow package suspension. Based on your experience do you think I am on the right track?
Old Mar 8, 2019 | 05:34 AM
SJMaye's Avatar
SJMaye
BTW- I made a mistake. My wheels are actually the 20" chrome PVD wheels.
Old Mar 8, 2019 | 08:44 AM
GlueGuy's Avatar
GlueGuy
There is nothing in the stock console that allows you to "fix" the circumference of your tires. People will generally use a tool like ForScan to edit the tire circumference.
May I ask?
Those 20" wheels/tires have the shortest sidewalls of all the various options, and will ride the roughest. Going to 18" wheels and tires with taller sidewalls can make a big difference in the ride quality. The max tow and/or heavy duty payload package will also make a difference. A Lariat (I don't think) can be gotten with heavy duty payload.
Old Mar 8, 2019 | 01:30 PM
SJMaye's Avatar
SJMaye
I did not see anything on the window sticker about heavy duty payload. Just Max Tow package. Seems the tire change will be the easiest. I will live with the ride until the wheel really look bad and tires need changing.
Thank you all for your help !
Old Mar 8, 2019 | 01:35 PM
CathedralCub
FTE Community Team
I agree, more sidewall and less wheel makes for a smoother ride pretty much regardless of the other suspension parts. It's all relative though. Going to an 18 will take the edge off, but won't make it ride like an LTD.
The aluminum body doesn't help though. Less weight to push down against a bump when the suspension is being pushed up will do that. I'm not sure if Ford changed the spring rates much when they changed to the aluminum body.
I know what you mean with your 2002, those rode less harshly (in my opinion) than the new ones.
Old Mar 8, 2019 | 02:46 PM
CR172's Avatar
CR172
IMO more sidewall equals a bouncier ride with less control in the curves. I went from the stock tires and wheels to stock wheels with LT275/70R18's and the ride was less comfortable and the handling went to s....t. I then went with a 20" Platinum wheel with P275/60R20's and I now have a nice comfortable quiet ride with much better handling.
Old Mar 9, 2019 | 09:02 AM
SJMaye's Avatar
SJMaye
I think it all a matter of taste. Prior to this all my trucks had standard truck tires with higher sidewalls. From the first time I got in this truck I noticed the harshness over bumps. It actually rattles the passenger seat when empty. I also agree with a previous poster that this is where the lighter weight of the truck may not help either.
Old Mar 9, 2019 | 12:24 PM
onug's Avatar
onug
I’m running the stock 18” rims with BFG load E tires. The ride quality changes from the squishy, 4-ply stock tires to these 7-ply tires was noticable. Less body roll and float, especially on turns.
Shocks are another reasonably priced option for changing the ride quality. I installed Bilstein 5100 series for a huge improvement.
Old Mar 9, 2019 | 04:13 PM
GABAR's Avatar
GABAR
Hi,
FORScan and maybe even some aftermarket tuners will be able to make said adjustment.
Errk20
Nov 2, 2017 10:37 PM
William
2015 - 2020 F150
16
Aug 8, 2017 10:27 PM
minnesotakim
May 19, 2008 12:23 PM
fordtruckman
2004 - 2008 F150
13
Oct 18, 2006 10:12 PM
03f150man
Oct 30, 2003 08:44 PM
