I currently have the stock 20in wheel and tire combo but just ordered new 20in wheels and 35in tires....will my speedometer be off? If so how do i correct? Newbie here dont hate me!!
The difference is the tire height not the wheels . If you had 34" stock tires your speedometer may be only off 1 mph or so. Check with a GPS if possible. Can be corrected with a programmer.
Happy to help you...
Not sure if you searched this forum but when you do you'll find answers to this and other questions.
any advice on how to use forscan to accomplish the adjustment? i have 35s but I can't figure out what value to put into the forscan app. the spreadsheet doesn't really have instructions for calibrating the speedo. I had 275x70R18s, and now have 35x12.5R20s
Follow the spreadsheet and change the value to xxxx 0A94 xxxx. That’s what I used for 295/65-20 (about 35.5” tires) and my speedometer is dead on with GPS.
perfect, i'll give that a shot! thanks! no issues with a check engine light? i've heard some codes for this will throw a code.
I used the 285 value listed on the sheet for my 35x12R18s and it's dead on. FYI.
So, just to be clear, all you changed was the last two digits of the middle set of numbers to 4C? Sorry trying to make sure I understand all this so I don't muck it up.
