Sponsored by: Real Truck
Tire age
Old Mar 7, 2019 | 08:28 AM
doubledip's Avatar
doubledip
Tire age
is there a brand that lasts longer age wise? I only put 3000 mi per year so my tires get old before they wear out. TY,John
Old Mar 7, 2019 | 08:45 AM
Chuck's First Ford's Avatar
Chuck's First Ford
all similar... my opinion.
in storage... parked for a time.
keep them out of the Sun...
keep them away from electric motors.
keep them from getting Wet..
keep them at 70 percent of max pressure..
do not use the Shine products...
do not let tires sit on dirt , gravel, concrete.... blacktop is not that bad...
pressure treated wood is OK.. as long as it stays DRY..
tires Rot..
steel rusts..
fact of life.
Old Mar 7, 2019 | 09:03 AM
don123's Avatar
don123
Tire manufacturers usually recommend 6 year replacement of tires regardless of miles. That doesn’t apply to me cause my tires are toast after 3 years. Keeping them out of the sun and inflated like Chuck said I believe would help.
Old Mar 7, 2019 | 11:16 AM
Batman7777's Avatar
Batman7777
Goodyear makes a tire that has lubricants in the sidewall to resist dry rot. These tire are usually made for RV's but maybe they have others.
RV tires tend to sit for months and even years. Sidewall movement is key to keeping the sidewalls flex'd and allow natural emollients to keep the sidewall lubricated.
I hear Ozone is a main contributor to dry rot. One good way to check for dry rot is look at the bottom and in between treads for cracks. This is often the first clue.
Yes, direct sunlight will accelerate the dry rot process. Call Goodyear and see if they have tires to resist dry rot.
Note: Even if aged tires (6 + years or more) look good from the outside, they may be coming apart on the inside. Tire carcasses tend to start separating inside and become weaker with age.
Another Note: Never put sidewall sprays or tire dressings on as this will greatly accelerate dry rot. Petroleum distillates is diesel fuel.
Old Mar 7, 2019 | 12:59 PM
Mike1's Avatar
Mike1
You can't stop rot but you can slow it down. This is some of the best stuff I've found so far.
https://www.303products.com.au/
Old Mar 7, 2019 | 01:03 PM
ford390gashog's Avatar
ford390gashog
Agreed 303 is the only dressing I would use.
Old Mar 7, 2019 | 01:07 PM
doubledip's Avatar
doubledip
How do you make sure your new tires are fresh?
Old Mar 7, 2019 | 02:06 PM
SnowPlowDriver's Avatar
SnowPlowDriver
There is a four digit code on all tires. First two numbers are the week ,next two numbers are the year. 0919 translates ninth week of 2019.
Old Mar 7, 2019 | 03:46 PM
sunuvabug's Avatar
sunuvabug
It's the DOT code i.e. DOT 5018 means the tire was made in the 50th week of 2018. Any tire you buy if it's within 6 months old would be considered fresh as they usually manufacture tires well in advance of the season for which they are intended. i.e. summer vs. winter tires
Old Mar 7, 2019 | 05:01 PM
brian42's Avatar
brian42
Veteran: Navy
After 10 years of age most reputable tire shops (Discount, Big O, etc.) will not touch them unless they are replacing them. This includes the spare.
Carolina Dually
May 24, 2011 07:32 PM
mndiesel
Jul 28, 2008 02:26 PM
khadma
General Automotive Discussion
May 11, 2008 04:34 PM
Markadeck
Mar 11, 2008 10:53 AM
randallc
Apr 29, 2003 08:15 AM
