Adding some power
Old Mar 5, 2019 | 09:06 PM
pstrokemike97's Avatar
pstrokemike97
Adding some power
Hi everyone, looking for some insight. Looking for some extra power , nothing crazy. Was thinking of installing a set of “baby swamps”, along with a reburn of my ts6 chip, along with a clutch upgrade to a reputable solid flywheel kit. Im not really interested in upgrading the rest of my fuel system or hpop. From my reading with the upgraded from stock but not crazy injector size that the swamps have, i should be OK without other upgrades. Currently i have a bone stock 97 f350 other than a tymar intake, 4 inch straight pipe and ts6 chip. Any ballpark ideas on hp& torque these could bring? Thanks
Old Mar 6, 2019 | 08:32 AM
knottyrope's Avatar
knottyrope
340 HP shown here, no torque rating mentioned
https://swampsmotorsports.com/produc...w-mild-street/
you might want to get something to monitor EGTs, it will heat up much faster with out an intercooler
Old Mar 6, 2019 | 12:58 PM
pstrokemike97
Would my stock clutch hold up to that power?
Old Mar 6, 2019 | 03:36 PM
knottyrope's Avatar
knottyrope
I wouldn't expect it to last long under full power since stock is around 210 HP
LUK and other makers have a few models with higher HP ratings
Old Mar 6, 2019 | 08:48 PM
Hit Man X's Avatar
Hit Man X
Luk easily holds up to 160/0s and big towing.
Do Comp 910s. Stock springs are weak and really clapped out with mileage. My turd revs so much easier with them. Spend the time to shim to correct height.
Old Mar 7, 2019 | 06:43 AM
DIYMechanic's Avatar
DIYMechanic
^^ X2
I'm running 160/0's from Rosewood (which I highly recommend, by the way) through a LUK stock replacement without any issue and it tows well. Reburn the chip with some good tunes for the injectors you decide on. E-fuel and a Super Duty 17* HPOP wouldn't be bad additions to your plans to provide a little bit of margin to build upon, but if you're conservative with the tunes and don't drive it like a rental, you should be fine with the stock HPOP and fuel.
I would definitely recommend getting an EGT gauge and a fuel pressure gauge in the truck since you'll be getting close to the limits of the stock turbo and fuel pump, but I think you'll be happy with the truck with those upgrades. I also elected to add a Riffraff billet compressor wheel to the turbo, and do a cheap EBP delete, but those are probably marginal gains over what you'll see compared to bigger injectors.
I did a video series on my YT channel showing the results (towing) after each upgrade if you're interested in seeing it.
Old Mar 7, 2019 | 01:59 PM
BBslider001's Avatar
BBslider001
LUK stock for the win. I tow heavy with mine with some extra HP. Going on 40k miles on a stocker. Great price and reliability.
Old Mar 8, 2019 | 05:39 PM
pstrokemike97
Good news i replaced the original oe clutch with a luk oe spec last spring, thats what i meant by “stock”
Ezalycasaid
Aug 23, 2015 04:52 PM
Lubbockguy1979
Mar 30, 2009 08:04 PM
Lance_I
15
Jul 9, 2006 10:00 PM
ForemanES
Oct 25, 2004 09:26 PM
73stroker
Feb 20, 2004 02:24 AM
