Guess my hp/tq
Guess my hp/tq
Im wondering what my horse power and torque numbers are. My buddy just did his on a dyno and hes got an 01 platinum 4 door with 35s, chipped, intake, and exhaust. He only showed 239 horses to the ground and 540 lbs of torque. Wich got me thinking. What is mine making. Ive got the stock 90cc injectors, bellowed up pipes, 6637 intake, 3" dp 4" exhaust, intercooler, and Tony wildman tuned. So what do yall think Id dyno at? Who here has ever dyno'd tony wildman tunes on stock turbo and sticks?
Stock injectors limit gains but you should be in the 230hp range. Spectulation on torque should be around double the HP number but I would imagine some of the older members on here would have a better idea as I personally have never really seen much in terms of physical proof for torque figures.
200-225hp and 365-400tq depending on dyno. Mine made 199&200 in december. Exh,intake,efuel,t500 ,50hp hyper tech chip.IMO it ran about as good as a stock stick,truck will.made 29-30 lbs boost and no haze even. Before the t500 boost was 23. Refuel fixed the deficiency in the stock system as my fuel pressure would drop from 75 idle to under 30 on hard accel. It was a sealed system with new pump and shimmed regulator.
I'm curious to see what I make now...not sure...
Spool&Go
36
09-15-2010 09:06 AM
Aberasturi_c
02-27-2008 06:45 PM
