Which clutch are the manual shifters using on chipped strokers?
I have been looking everywhere for a good clutch with a higher tq rating. Just wondering what everyone else has done. I checked in with south bend clutch they said they can build whatever I need. Any help would be appreciated.
I've used South Bend with great results. Before I started pulling I used the CON OFE. At that time I was at 400 rwh. Never jerky even when towing. I'm now on my second twin disc SB. You can call Larry to get price and more info..
http://www.discountpowerparts.com/
99-03 Power Stroke - MU 1944 6sp - Stock Power
99-03 Power Stroke - MU 1944 Con O 6 sp - 350 hp, 750 ft lbs of torque
99-03 Power Stroke - MU 1944 Con OFE 6 sp - 450 hp, 900 ft lbs of torque
99-03 Power Stroke - MU 1944 Con FE 6 sp - 550 hp, 1100 ft lbs of torque
Check out the SB link. On the left side of the page there is a link to one of my pulls . Kevin@
http://www.southbendclutch.com/dd.html
Hey Kevin thanks for all the help. Is Larry at discount power parts or south bend? What would you suggest as some basic mods to do while I got some time off? I read something about different bolts for the 7.3 cause stock ones won't hold over 400hp. What about this 10k or 18k mod? Which one is best and can I run that with my chipwithout any problems? Just looking for ideas to keep me busy for two weeks.
Larry is at http://www.discountpowerparts.com/. Before we talk mods you need to make sure what rods are in your engine by looking here. http://www.dieselinnovations.com/gal...spection_hole/
If you have forged they will take a lot more power. The powdered metal rods are brittle and you have to be real carefull. Also do you have gauges?
Okay thanks again for all the help. I'll have to look at it later. Gotta go to work until wed. at least. Looks like you gotta drain the oil and take the pan off so I'll need more time than what I have right now. If I do have the forged rods what were you thinking about the mods. I heard the 18k shouldn't be used with a chip because it messes with stuff the chip might already be doing.
it looks like you need to remove the pan, only because that writeup was done on an engine out of the truck that had the pan off ready for a teardown. no oil comes out of the hole, the oil level is way below the pan rail.
