Switch Panel and Wiring HELP!
Old Mar 4, 2019 | 04:31 AM
Adam Roberts's Avatar
Adam Roberts
Question Switch Panel and Wiring HELP!
hope this heps/is useful in some way.
1975 F-100 Custom 4x4
Insert relays and anything else I need anywhere.
Three long years of a build is all coming down to this! I've built and done everything myself. Aside from the cab mounts, the bed bolts and the fenders... I've touched or changed everything part of this truck. I just can not get a grasp on the wiring. I have attached a diagram of all my new components as well as a list. Any and all help will be greatly appreciated. I am new to the members part of this site, but have used its knowledge dozens of times. I excited to create a build album of her once I'm finished. Again, thank you for your time.
Jegs 4 toggle switch panel
Joes 4 terminal battery disconnect
BP Automotive Off Road Power Distribution Block
Edelbrock electric fuel pump 1791
Derale dual fan shroud (fan #1 is controlled by an adjustable radiator probe fan #2 will be switch on the panel)
-5 Fused/Relayed circuits (30)
-5 Fused Circuits (15)
CSR electric water pump 904fe-b
I started to run the switch panel as if starting from scratch but then remembered that I still had to grab the stock switched accessories from the key cylinder and stopped there. I hope my diagram Is something anyone can use. If there is anything I can do please don't hesitate. I really appreciate any and all help. I can see the light, just need a little push to get there! thanks guys!
I offered this to a few of my buddies so I figured why not to you?? Ill Venmo the person who sends me the schematic that works the best $20.
Old Mar 4, 2019 | 06:20 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Welcome to FTE, maybe this random collection will help shed some light or get you going in the right direction. I am smart enough electric wise to shock myself...twice. lol
Some info in here if you read and scroll a bit, well scroll alot....the elec section is sort of grouped together around Post #10, post #68 a good one. Looking forward to seeing your build.
https://www.ford-trucks.com/forums/1...then-some.html
Good threads...https://www.ford-trucks.com/forums/1...viii-fans.html
And another great one https://www.ford-trucks.com/forums/1...ing-101-a.html
https://www.ford-trucks.com/forums/1...ch-thread.html
https://www.ford-trucks.com/forums/1...lp-please.html
Hot Rod Wiring and How to Do It
OEM elec color guide chart https://www.classiccarwiring.com/for...lphaasc&page=3
Motivation:https://www.ford-trucks.com/forums/1...storation.html
Adam Roberts
Electrical Systems/Wiring
Mar 4, 2019 06:30 PM
nastyss
Feb 1, 2013 03:51 PM
E-350/Vantel29
Jul 8, 2012 09:09 AM
mercman86
2004 - 2008 F150
Mar 4, 2009 10:37 PM
