Upfitter Switch
Old Jul 7, 2012 | 11:47 PM
E-350/Vantel29's Avatar
E-350/Vantel29
Upfitter Switch
I bought a 2012 E-350. I am trying to wire in LED strobes to the existing upfitter switch. There are 4 switches, aux 1 is used for PTO, aux 2 is used for aerial lift strobe. I have 3 & 4 available. I'm guessing the upfitter is wire harnessed to a fuse panel. I would like to have switch 3 control the LED strobes. Where do I run the wiring to? Where is the fuse panel that the upfitter is wired to? Any help would be greatly appreciated.
Old Jul 8, 2012 | 07:06 AM
Franklin2's Avatar
Franklin2
See what this link has in it, I have dial-up and it took too long to load in.
https://www.fleet.ford.com/truckbbas...rical_v1.0.pdf
What you need to know is on this site, https://www.fleet.ford.com/truckbbas/ it's just a matter of finding it. It will look like this, here is a link for a 2008 truck
https://www.fleet.ford.com/truckbbas..._pdf/index.pdf
Old Jul 8, 2012 | 09:09 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Vantel, you don't have the owner's manual for this truck? It's in there. If you don't have it, it's avail via myford.com
xmontex4
Jul 20, 2013 10:36 PM
JethroF250
Jul 23, 2009 11:55 AM
beforeiforget761
May 10, 2009 09:35 PM
Masterchief6098
Oct 13, 2007 09:28 PM
bronco351
1978 - 1996 Big Bronco
Nov 4, 2002 02:33 AM
