I need to replace mine bc some jackwagon drilled holes in it for what Im guessing was a 6 gun tuner switch.I looked on Tousley's site and the panel without the 4wd or airbag switch is $140,but the one for 4wd without the airbag switch is $405!!!!Naturally I need the more expensive one.My question is what makes the panels with the 4wd switch $300 more?From what I recall they are both the same but one is cutout for the switch.Part #8
I tried finding a used one,but Im one picky sob.For a little more than people want for used Im gonna buy the new cheaper version and cut the opening for the 4wd switch.Just need to figure out the exact color I need.
