Fuel separator
Old Feb 28, 2019 | 02:06 PM
Jason6368's Avatar
Jason6368
Fuel separator
Hello, new guy here... new to diesels as well as new to the forum. I tried the search and didn’t find exactly my question. I have a ‘17 and I turned the petcock of the water seperator and I kept getting water. Don’t hate but I’m assuming that diesel is coming out too and if I keep it open it will just continue draining diesel fuel? How do I know how much to drain out? How often should I drain it?
Old Feb 28, 2019 | 03:07 PM
Just Strokin's Avatar
Just Strokin
get a clear plastic container or glass jar....drain about 4 to 6 ounces....most water you can see easy if the amount is more than minimum......if no water present, and then let it sit 10 minutes to see if any settles out....
Diesel floats on water.....so water should come out first if any
Old Feb 28, 2019 | 09:06 PM
No.15's Avatar
No.15
Be sure it's water by letting it separate in a clear container. The fuel I buy is totally clear like water , diesel can be a few different colors from clear to green or yellowish
Old Feb 28, 2019 | 10:50 PM
HRTKD's Avatar
HRTKD
If you fill the jar and all the fluid looks the same then add some water so you can see what it looks like when added to diesel.
So far, no water in any of the tests I've done.
Old Mar 1, 2019 | 10:50 AM
Jason6368's Avatar
Jason6368
Awesome, thanks guys. I must have wasted a gallon of diesel thinking, damn did the dealership ever change this water out?
Old Mar 1, 2019 | 10:54 AM
HRTKD's Avatar
HRTKD
If you had THAT much water your engine would be dead, dead, dead.
Old Mar 2, 2019 | 06:11 AM
senix's Avatar
senix
usually the first second or two will have the water if any. In the past I have gotten some and what appear for me was some bubble followed by a clear and steady stream.
Not my current truck...but in my 08 6.4.
Icthus in AK
6.7L Power Stroke Diesel
21
Jan 12, 2017 03:47 PM
belas
Feb 11, 2014 09:57 AM
asemastermech
General Diesel Discussion
May 26, 2012 08:57 PM
Mnytalks1
6.4L Power Stroke Diesel
Jul 4, 2009 10:07 AM
Mnytalks1
15
Oct 27, 2008 12:06 PM
