6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Water Seperator
Old Oct 25, 2008 | 01:32 PM
Mnytalks1's Avatar
Mnytalks1
Water Seperator
My truck has 7700 miles on it and I have never seen a message that tells me there is water in the fuel. The manual says to open the water seperator once a month but I'm a little hesitant to do that if its not needed. Anyone have any advice? I'm new to this diesel thing and I don't want to create a problem.
Old Oct 25, 2008 | 02:07 PM
Stalwart's Avatar
Stalwart
DO IT! You cannot afford to not drain the water, it will kill the injection pump and injectors if your filters fill with water and allow water to get past them. Draining the water trap is easy, and be sure to turn on the key for 10 seconds or so before trying to start the truck after draining.
Old Oct 25, 2008 | 04:49 PM
Mnytalks1's Avatar
Mnytalks1
Stalwart,
Thanks, I just did it. It seemed to all be diesel fuel. I expected some water but there did not appear to be any. It was easier then I thought.
Old Oct 26, 2008 | 11:17 AM
Jimmy63's Avatar
Jimmy63
Same thing here. Did a check at 7000 miles and nothing but pure ULSD! I try to always buy at my local TA truck stop/BP. Fresh fuel on a daily bassis. By the way, diesel is $3.03!!! (and dropping)
Old Oct 26, 2008 | 01:17 PM
Mnytalks1's Avatar
Mnytalks1
$3.03..awesome, here in Florida still $3.49.
Old Oct 26, 2008 | 03:49 PM
senix's Avatar
senix
took the opportunity to drain mine today as well, nice warm day and rather easy to do the drain. 3.29 here in maryland so far.
Old Oct 26, 2008 | 05:11 PM
firstfordf25008's Avatar
firstfordf25008
I bought my truck slightly used w no owners manual and have no idea where this drain is? I have about 13000 miles on the truck and it has never been done. $2.89 per gal phx az
Old Oct 26, 2008 | 05:17 PM
kawtiper's Avatar
kawtiper
If I recall correctly, it is right under your azz on the inside of the main frame rail. All you need is a plastic cup but I use a clear container so I can see what I am doing.
Old Oct 26, 2008 | 05:21 PM
Mnytalks1's Avatar
Mnytalks1
This link should help you. The only thing I noticed is the picture makes the handle and drain look larger then it actually is. superduty
Old Oct 26, 2008 | 05:27 PM
kawtiper's Avatar
kawtiper
Where are you located the cheapest I have seen is 3.29 in WA
Old Oct 26, 2008 | 08:12 PM
Jimmy63's Avatar
Jimmy63
Sorry, I didn't mention that I am in Indianapolis. Just checked the TA website and we are down to $2.99!
Happy days are here again (for fuel prices!)
Old Oct 26, 2008 | 09:14 PM
KenShaw's Avatar
KenShaw
I have 8000 miles on my 6.4 and i have tried to drain several times but i get only a few drops of fuel, no water. The drops come very slowly. Should there be a steady stream of fluid from the filter?
Old Oct 26, 2008 | 10:00 PM
bubbla's Avatar
bubbla
I did mine yeserday for the first time - 6 months - 3800 miles. All fuel - no water.
I paid $3.29 Friday in CA (east bay area)
Old Oct 27, 2008 | 05:01 AM
senix's Avatar
senix
Should be a steady stream, are you opening the valve all the way?
Old Oct 27, 2008 | 11:58 AM
BTXpress's Avatar
BTXpress
$3.45 in Montgomery, AL. I wish it was under $3/gal here. I will be taking our truck back to the dealer for the Drain Fuel/Water Separator message. Dealer said last week that nothing was wrong, but I can't drive more than 7 miles before the message comes back on. I have drained mine several times. Dealer supposedly checked the sensor, and our fuel and said nothing was wrong. I'll be looking at changing the fuel filter.
When you drain yours... is your truck level?
