Sponsored by: Real Truck
Spacers
Old Feb 28, 2019 | 01:38 PM
diamondrcattle's Avatar
diamondrcattle
Spacers
Looking for 1" or more spacer to put between duals on 15 F350. Its a feed truck so hauls quite a bit of weight. Tire man cant find any that he thinks will work or handle the weight Any ideas? Thanks guys
Old Feb 28, 2019 | 08:15 PM
tlcsr66's Avatar
tlcsr66
Are you talking about a spacer between the axle and the rim?
Old Feb 28, 2019 | 08:17 PM
diamondrcattle
No put between the tires ton widen the gap. Only a finger width now and mud goes in but wont come out
Old Feb 28, 2019 | 08:21 PM
Djosbun's Avatar
Djosbun
I would HIGHLY not recommend that.
— Dave
tlcsr66's Avatar
tlcsr66
Ahhh! Ok. Sorry I don't have any ideas but at least I got your post bumped back up to the top.
Old Mar 1, 2019 | 09:39 PM
EDC8008's Avatar
EDC8008
The wheel studs were not designed for the additional stress and that puts them at risk for failure. Same issue with a single wheel to move them outward for more clearance. That’s why our trucks have Hub Centric wheels to help reduce this but it does not eliminate the additional stress. Add to it as the wheel rotates the stress also does as they follow the rotation. Think about when you take a piece of metal and start moving it back and forth at first it is pretty difficult but it soon starts to move easier and more. Then it breaks. If this is thelug nutsthere goes the wheel.
A lotta guys do it but I would highly recommend not.
i work in the energy industry and have seen what happens when a high speed coupling comes apart when someone decides he can double the spacer thickness in a coupling, kinda like adding a shim between the wheels. 3600 RPM at 15,000 brake horse power and it becomes shrapnel.
Old Mar 2, 2019 | 03:36 PM
Mike189677's Avatar
Mike189677
If you find a good quality hubcentric spacer you will be fine if you are using the stock hub centric wheels. I think a lot of people don’t realize that dually a come from the factory wth spacers in the front.
Old Mar 2, 2019 | 03:42 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Here you go, only company I would trust for this kind of thing. No China sh$t here
https://www.wheeladapter.com/dually-wheel-spacers
Old Mar 2, 2019 | 03:54 PM
diamondrcattle
Thanks guys. Wheel centric and hub centric, what does that mean? Tire guy didnt like the outside wheel not resting on hub lip and only resting on lugs. Any thoughts? Darn mud just creates problems....shakes the hell out of things going diwn the road.
Old Mar 2, 2019 | 03:59 PM
SuperDutyScaler
Lug centric uses the lug nuts to center the wheel on the axle. It's not great and is not for a heavy duty truck.
hub centric has a lip on the hub face that matches the opening of the factory wheel. This perfectly centers the wheel and places the load oh the hub face and wheel and not the lugs.
Ford uses hub centric and the link I posted also uses hub centric high grade steel spacers that will be safe for what your truck needs
Old Mar 2, 2019 | 04:01 PM
SuperDutyScaler
Also on our dump trucks we got three or four links of chain to the mud flap. The chain rides between the duals and cleans out debris when the dump is up
diamondrcattle
Thank you for all your help!
KYLongRifle
Feb 16, 2017 05:45 PM
BFSD350
May 30, 2007 04:14 PM
tkd
Dec 14, 2004 10:00 PM
celrifai
Aftermarket Products
Sep 22, 2003 06:21 PM
