Death wobble still?
Old Feb 28, 2019 | 01:12 PM
Korbin's Avatar
Korbin
Death wobble still?
i have a 1980 f150 ranger 4x4 5.0 np435 and I can go 80mph smoothly but I hit any bump going any more than 30mph and I get the worst death wobble I’ve ever felt nearly loosing control of the vehicle unless I lock up the brake then it’ll straighten out. I replaced all bushings including radius arm bushings and one tie rod had a little play so got a new one. New power steering pump and steering gear box and nothing changed about the death wobble. Literally have no idea what to do now. I’m doing the rag joint today even though it has zero play in it and hopefully that helps. If I’m forgetting something please let me know. Thanks
Old Feb 28, 2019 | 03:36 PM
FuzzFace2's Avatar
FuzzFace2
Back on the 60's vans with leaf springs & straight axles you be driving down the high way at 60+ MPH hit a little bump and all hell broke loose!
Like you, you would have to jump on the binders and slow down to a craw for it to stop.
Once you saw what was going on the fix was easy.
What was the fix you ask?
Front Shocks!
You hit a bump and the front axle would start bouncing like crazy.
Shocks are to keep that from happing.
Shocks are cheap and how old are the ones on your truck?
Dave ----
Old Feb 28, 2019 | 05:47 PM
Franklin2's Avatar
Franklin2
I agree, shocks could be it. I have had that happen before myself, but it turned out not to be the shock itself but the shock mount was loose.
Old Feb 28, 2019 | 10:33 PM
bobs 80 f250's Avatar
bobs 80 f250
Try replacing the axel pivot bushing. I’ve experienced this and had it replaced. My truck is lifted,and had it replaced when it was done. Never any problems
Old Mar 1, 2019 | 02:33 AM
FuzzFace2's Avatar
FuzzFace2
He said he replaced all bushings but nothing on the shocks and why I said shocks.
Dave - - - -
Old Mar 1, 2019 | 08:08 AM
BigBlue2's Avatar
BigBlue2
Dave - - - -
It's been my experience that shocks last about the same amount of time as a set of tires. If you go over a bump and there is any hobbyhorsing it's time to replace them. I bought lifetime guarantee shocks from my tire dealer. I don't think they expect people to have the same truck for 33 years. I have gone through a lot of free shocks. I would recommend that you get the heavy duty type shocks for your truck.
BB2
Old Mar 2, 2019 | 12:58 PM
Korbin's Avatar
Korbin
Thanks guys for all the help I’ve been busy with work the past couple days. I’m definitely going to try the shocks they are 100% blown. I didn’t even think about that. Thanks
Old Mar 2, 2019 | 04:25 PM
FuzzFace2's Avatar
FuzzFace2
100% blown!
I would say 100% that is the problem.
With the early vans and I bet with your truck you hit a bump and the tire starts bouncing and will not stop till you almost come to a stop.
If the front are that bad think what the rear may be like.
Keep us posted as we like to know the out come.
Dave ----
Old Dec 15, 2019 | 04:13 AM
Korbin's Avatar
Korbin
I know I’m really late
I know this is almost a year late but it’s been broken for a long time. But the actual cause was the mount that the driver side traction beam mounts to someone welded it on super sharty and the welds were breaking I’m lucky they didn’t fully brake so I just welded it back on but actually did a decent job with it (I’m a fabricator for a living). I figured I’d post this for anyone else that’s having the same problem and are trying to find possible causes
Old Dec 15, 2019 | 06:35 AM
FuzzFace2's Avatar
FuzzFace2
Korbin,
Thanks for the feed back, as you said it may help someone else.
Dave ----
Old Dec 16, 2019 | 03:35 PM
1TonBasecamp's Avatar
1TonBasecamp
Definitely.
You didn't also happen to rotate or change the tires at about that time by any chance, did you?
Paul
catfisherman369
Dec 31, 2016 10:39 PM
Gwilkrrs
6.4L Power Stroke Diesel
Jun 26, 2012 08:00 AM
Aftrmidnite
Aerostar
Jan 9, 2004 02:03 PM
mwkellner
Dec 18, 2000 10:27 AM
mwkellner
Feb 24, 2000 06:50 AM
