6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
front end squeak....
Old Apr 25, 2012 | 06:05 AM
Gwilkrrs's Avatar
Gwilkrrs
truck is an 08 350 leveled. i had an annoying loud high pitched squeak from the front when hitting bumps. i thought it was due to bad shocks. i replaced the shocks and this cut down on the frequency of the squeak but it is still there. what else could be the culprit?
recent work includes= new shocks, new steering stabilizer, new trac bar and bushings, new drag links and 1 tie rod............
Old Apr 25, 2012 | 07:56 PM
slowmans's Avatar
slowmans
did you lube the new bushings?
Old Apr 26, 2012 | 07:00 AM
Gwilkrrs's Avatar
Gwilkrrs
i only did the shocks, the dealer did the rest. i did not lube the shock bushings. should i? what type of lube? never thought this.....
Old May 9, 2012 | 05:47 PM
pwarren68-2008's Avatar
pwarren68-2008
My 2008 has the same damn squeak..had it since day one..took back to dealer a few times. Of course they could not hear it..replaced the shocks..squeak still there. I am known at work now as squeaky Pete...anyone know what this High pitch squeak can be? Man it is annoying!!!!!
Old May 10, 2012 | 05:42 AM
Gwilkrrs's Avatar
Gwilkrrs
i took mine into the dealer, they put it on a lift and checked and said nothing is wrong.... drove it and said nope didnt hear it...... wouldntr let me in shop or truck with them though...... i drive of lot frustrated and it squeeks! crazy......
if i have time i will put mine on stands this weekend and check......
Old May 10, 2012 | 07:46 AM
senix's Avatar
senix
What about the bushings in that stabilize the front axle. They connect on the rear of the axle and then farther back on the frame.
Old May 11, 2012 | 06:47 AM
Gwilkrrs's Avatar
Gwilkrrs
senix- good question, i will check that this weekend! thanks
Old Jun 25, 2012 | 06:29 AM
Gwilkrrs's Avatar
Gwilkrrs
i think i have figured out the sqeek! the adjustable trac bar is hitting and rubbing a shiny spot into the main bracket behind-above it. now to find out why the interference that the dealers couldnt find.....
Old Jun 25, 2012 | 07:18 AM
senix's Avatar
senix
Do you think it has been bent?
Old Jun 25, 2012 | 08:08 AM
Gwilkrrs's Avatar
Gwilkrrs
i have not hit anything, bumped anything or anything that would be an issue. going to shop tonight with the old bar to see if they are shaped differently.... the new adj bar is large in diameter- i cant see it bending.....
Old Jun 26, 2012 | 05:56 AM
Gwilkrrs's Avatar
Gwilkrrs
the stock bar has a slight bend-curve tio it that pushes the bar to the front of the bracket- the adjustable brackt is straight. dealer told me to grind or cut the effected area off the bracket to clearance it.......
he said the level kit actually pushes the front end down and rotates it back slightly bringing the bar and bracket closer then stock......
Old Jun 26, 2012 | 07:48 AM
senix's Avatar
senix
Reasonable explanation. I don't think this fix would comprise anything.
So it boils down to a design issue on the aftermarket part.
Old Jun 26, 2012 | 08:00 AM
Gwilkrrs's Avatar
Gwilkrrs
exactly- he brought a stock one over to hold up next to mine to show and explain-
ranchers_wife
Jan 7, 2009 07:17 PM
Aftrmidnite
Aerostar
Jan 9, 2004 02:03 PM
mwkellner
Dec 18, 2000 10:27 AM
