Fuel Issues
Old Feb 27, 2019 | 10:54 AM
Motolover's Avatar
Motolover
Originally Posted by ReForder
Back to the main issue, though....you say there is no vacuum on the inlet side of the fuel pump when you attach a gauge there? This still has me leaning towards a fuel pump issue...bad diaphragm, gunk inside of it, or push rod not actuating on the cam correctly.
yes that's what I'm thinking I get zero vacuum on the inlet side of the pump, could one of the fittings be sucking air causing the pump to not build vacuum?
Old Feb 27, 2019 | 10:55 AM
Motolover's Avatar
Motolover
Originally Posted by ALBUQ F-1
Basic adjustment of the idle mixture screws is 1-1/4 to 1-1/2 turns out from lightly bottomed.
Raise your idle speed on the passenger side of the carb, there is a screw that bears on the choke operating arm.
With a full tank of gas, the fuel level in the line will be at about the exhaust level on the engine. A good pump will suck gas up the line to the pump inlet in a few revolutions while cranking. I suspect your pump either has junk on the check valves, or a leaking diaphragm.
is there any other adjustment on the carb besides the 2 idle mixture screws?
Old Feb 27, 2019 | 10:58 AM
ReForder's Avatar
ReForder
You mean the fuel line fittings? If you put the vacuum gauge directly on the pump and it pulled no vacuum, that would eliminate the fuel line fittings between there and the tank. To rule out the pump, you could remove it from the engine, put small hose into a jar of gasoline and operating the pump actuator rod by hand to see if it pushed fuel out the other side. Do this LIGHTLY as you could damage the diaphragm inside if you crank on the actuator arm. If it works, pump is good. Just a matter of how it sits on the cam then, or a problem with the lines/tank fitting.
Old Feb 27, 2019 | 11:36 AM
ALBUQ F-1's Avatar
ALBUQ F-1
There is a section of hose at the end of the fuel line, that goes into the fuel pump inlet. It is very common to be leaking either air or fuel. Maybe you replaced it when you did the lines?
There are no other adjustments.
Old Feb 27, 2019 | 02:14 PM
Jersey devil's Avatar
Jersey devil
Is the gasket on top of the sight glass on the fuel pump missing?
Ask me me how I know,
Tom
Old Feb 27, 2019 | 03:54 PM
Motolover's Avatar
Motolover
ok I'll have to try that and see, thank you for the help.
Motolover's Avatar
Motolover
Tom
no I made sure to check that, gasket it there and fuel bowl is good and tight.
Old Feb 27, 2019 | 03:56 PM
Motolover's Avatar
Motolover
yes I replaced it, it was very dry rotted
Old Feb 27, 2019 | 05:09 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Replacement fuel pumps are relatively inexpensive. You can get them from the local parts places:
https://www.napaonline.com/en/search...h_form-allprod
https://shop.advanceautoparts.com/p/...986%7CL3*15378
You might also want to look at your fuel pump push rod. They are known to wear which shortens their length which shortens the stroke on the pump making it move less fuel...
Old Apr 3, 2019 | 07:02 PM
Motolover's Avatar
Motolover
Well I put a new fuel pump on and it fired right up! Still runs a little rough but way better than it was! Thanks for all the help!
Old Apr 4, 2019 | 04:02 AM
FortyNiner's Avatar
FortyNiner
Good to hear. Between carb and timing adjustments, you should smooth out things.
Wizard19
Escape & Escape Hybrid
Aug 19, 2018 02:30 PM
1950F47
13
Apr 14, 2014 05:15 AM
ke6jcf
19
Jun 4, 2013 07:04 PM
Steel357
Feb 18, 2008 08:50 AM
Seifferlein
Apr 20, 2004 04:07 PM
