Fuel Issues
Old Feb 26, 2019 | 03:34 PM
Motolover's Avatar
Motolover
Fuel Issues
So i recently rebuilt the holley 94 carburator and replaced the fuel pump on my 1950 f1, but I am having trouble getting the pump to suck the fuel from the tank. I have ran a new fuel line from the tank to the pump. when I put my vacuum gauge on the inlet side of the fuel pump i get zero vacuum when i crank over the engine. I am not very familiar with older carburated systems so any help would be greatly appreciated! TIA
Old Feb 26, 2019 | 04:06 PM
FortyNiner's Avatar
FortyNiner
Is the tank behind the seat with the fuel line tapped into the bottom?
Old Feb 26, 2019 | 05:06 PM
raytasch's Avatar
raytasch
Believe Nothing
Originally Posted by Motolover
replaced the fuel pump on my 1950 f1, but I am having trouble getting the pump to suck the fuel from the tank. I have ran a new fuel line from the tank to the pump. when I put my vacuum gauge on the inlet side of the fuel pump i get zero vacuum when i crank over the engine.d! TIA
You should see vacuum at the pump inlet when the engine is rotating. What engine are we taking about?
i
Old Feb 26, 2019 | 05:09 PM
seaves46's Avatar
seaves46
Have you had this engine running before ?
Try removing the fuel pump and operate it by hand , put your finger on the intake and see if it produces vacuum .
If it does it may be the fuel pump pushrod is too short .
Old Feb 26, 2019 | 06:59 PM
Motolover's Avatar
Motolover
yes the fuel line is behind the seat with the fuel line tapped into the bottom, it has a 8ba flathead in it, i can get the engine to run if i prime the fuel line, the engine will run but i have to keep my foot on the throttle a little or the engine will die. the engine will not idle.
Old Feb 26, 2019 | 07:40 PM
Motolover's Avatar
Motolover
Old Feb 26, 2019 | 08:28 PM
raytasch's Avatar
raytasch
Believe Nothing
If it will start and run on the existing fuel supply, your pump is working. It may not be working as it should. Have you adjusted the carburetor since rebuild? Do you have instructions on carburetor adjustments? Will the engine speed increase with throttle increase? Will the engine run with the choke pulled part way out?
The more accurately you can describe your problem, the easier and quicker we can determine the problem and help you fix it.
Old Feb 26, 2019 | 08:56 PM
Motolover's Avatar
Motolover
To be honest i dont know too much about adjusting the carburetor. i have messed around with the 2 idle mixture screws but they dont seem to do very much unless i tighten them both in then the engine will die. the engine speed will increase with throttle increase, and it will run with the choke pulled 1/4 of the way out. if i push the choke right in the engine will die. i also have the vacuum port that goes to the windshield wipers plugged. if i quickly put my foot to the floor the engine dies aswell.
Old Feb 26, 2019 | 09:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Basic adjustment of the idle mixture screws is 1-1/4 to 1-1/2 turns out from lightly bottomed.
Raise your idle speed on the passenger side of the carb, there is a screw that bears on the choke operating arm.
With a full tank of gas, the fuel level in the line will be at about the exhaust level on the engine. A good pump will suck gas up the line to the pump inlet in a few revolutions while cranking. I suspect your pump either has junk on the check valves, or a leaking diaphragm.
Old Feb 27, 2019 | 04:21 AM
FortyNiner's Avatar
FortyNiner
Let's check a couple of basics :
When the line was replaced, did you check and clean the connection at the bottom of the tank? Crud build up can easily reduce the flow of fuel.
All line, pump, and carb connections are tight?
Vacuum lines tight?
If none of these items are a factor, then Ross' carb/pump comments are your best guide.
Old Feb 27, 2019 | 05:39 AM
Motolover's Avatar
Motolover
The fuel tank and valve at the bottom of the tank were cleaned prior to install in the truck. As far as the idle screws on the passenger side of the carb the screws is tightened all the way in and it barely touches the adjuster. I have attached pictures.
Old Feb 27, 2019 | 06:07 AM
Motolover's Avatar
Motolover
I should also note that those pictures were taken before the carb was taken apart and cleaned, but the linkage setup is still the same. I will pull the pump off this weekend and try everything you gentlemen suggested. I really appreciate the help, I just want this old girl to purr like she did 69 years ago.
Old Feb 27, 2019 | 06:15 AM
fordf348's Avatar
fordf348
I'm betting crud in the tank, that will drive you nuts until you install a new tank
Old Feb 27, 2019 | 09:05 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That screw that barely touches the throttle cam needs to be longer. I'm not sure if it is a special (unusual) thread pitch.
Old Feb 27, 2019 | 10:45 AM
ReForder's Avatar
ReForder
Back to the main issue, though....you say there is no vacuum on the inlet side of the fuel pump when you attach a gauge there? This still has me leaning towards a fuel pump issue...bad diaphragm, gunk inside of it, or push rod not actuating on the cam correctly.
