Any mechanical fuel pump gurus out there?
My truck is a 56 with a 292 in it. I put a tank in the back, where a spare tire might go, the pick up for the tank is lower than the mechanical fuel pump. Is this a problem? I know if I use an electric pump I need to have the pump lower than the tank in order to have a gravity prime, is this the case with mechanicals as well? Thanks for your input,
-Doug
-Doug
I'm no guru either, but if you think about it, the fuel line coming out of even the stock tank behind the seat is lower than the stock mechanical fuel pump. Like Ray said, sometimes they have to crank a while. I think it took about a minute for my truck to put the fuel into the carb today after sitting for a couple weeks.
Check the steel fuel line from tank to front of the truck. Anywhere the line clamps to the frame is a suspect area for rust. And of course, check the fuel hose for holes. Any hole at all and it is not going to draw fuel.
Yeah but where did the fuel line come out of that tank? I know the fuel pumps were lower on those engines, but I still would think it would be higher than any fuel line coming along the bottom of the cab.
Mechanical fuel pumps, when the check valves are working properly pull as much vacuum as pressure since the diaphragm pulls vacuum on half the stroke and pressure on the return. Most cars up into the 70s had the fuel tank low in the back under the trunk. f the carb leaks and goes dry when sitting, the check valves in the pump can go dry and stick or fail to seal enough to self prime.
Fuel lines
All the fuel lines are new and the filter is new. The tank outlet is about 8" lower than the frame rail in the back. I took the pump out and manually maneuvered the actuator arm, it sounded like it was working but that's not very scientific. By the way the fuel line is mounted to the bottom of the frame rail. Thanks for all of your responses, it's going to make figuring out this issue a lot easier. By the way, just finished the Toyota PS conversion, very simple to do even with the body on. Purchased the PS hoses from Midfifty, all of the adapters and everything else needed to make it work were included. Made the job even easier.
Thanks
-Doug
Thanks
-Doug
So hold the pump, vice preferred, work the arm while sticking your finger over the inlet side and you will feel the suction. If the pump is working, you'll feel pressure on the discharge side.
Edit: If you keep your finger on the inlet side the pump should hold the vacuum for quite a while, minutes or longer.
If no fuel check the filter in the fuel line. On mechanical fuel pumps the clear fuel filters are your best friend.
If no fuel check as described above. If the pump is good and no fuel pull the fuel line from the tank. Often they have a mesh "sock" filter.
One last thing to check, open the gas cap. If you hear a rush of air in you have the tank sealed and air needs replace the fuel on these old systems.
I'm no expert or guru, just old enough to have experienced pre emissions vehicles.
Thanks
-Doug
Thanks
-Doug
A combo vacuum/pressure gauge is inexpensive and essential when working on carburated engines and should be in everyone's tool box.
I haven't seen it mentioned, but does this mechanical pump have a glass bowl? If so, the gaskets on them are highly suspect and a common leak point.
