Excursion Skid Plate
Old Feb 25, 2019 | 01:19 PM
kkrapp's Avatar
kkrapp
This has almost certainly been discussed but I'm not finding anything directly on point so I'll just ask: Are there any F250 or F350 skid plates that bolt onto a '00 Excursion? I've struck out looking for Excursion-specific plates. I'm looking for some front-end protection from rocks, as I've repaired too many steering stabilizers and sway bars over the past few years. If not, I'll just have to build something I suppose.
Old Feb 25, 2019 | 02:56 PM
seijirou's Avatar
seijirou
As far as I know everything forward of the frame splice is basically the same as the superduties.
Old Feb 25, 2019 | 03:01 PM
pirate4x4_camo's Avatar
pirate4x4_camo
better off getting a high steer setup and moving that stuff up and out of the way, also switch to the rwd ex sway bar as it is frame mounted so it is out of the way
Old Feb 25, 2019 | 06:32 PM
01FordEx's Avatar
01FordEx
Pirate I have been wanting to try that for a while now. I see a couple hurdles but nothing major. Have you done this by chance with leafs? I know you are on coils now I believe...
Old Feb 25, 2019 | 07:56 PM
pirate4x4_camo
Which part ?
havent done it to my Ex on leafs since like you say on coils but have done it to others on leafs.
Old Feb 25, 2019 | 09:24 PM
01FordEx's Avatar
01FordEx
Originally Posted by pirate4x4_camo
Which part ?
Sorry wasn’t very clear. Referring to the 2WD front sway bar.
Old Feb 25, 2019 | 10:33 PM
pirate4x4_camo
need to weld some tabs on the housing to mount the end links but it should be straight forward. Might need to get a little creative with the link itself but it’s seems doable
Old Feb 25, 2019 | 10:56 PM
01FordEx's Avatar
01FordEx
Mounting, links, etc. I can handle. From what I have seen I don't think the 2wd front sway bar itself will work based on its "shape." I could certainly be wrong as I haven't test fit anything, just looking at junkyards.
I guess I will have to do it so there is some solid info out there...
Thanks Pirate!
mwsF250
Apr 2, 2009 09:20 AM
jdbanks
Jun 20, 2005 10:38 AM
Boss50
General Automotive Discussion
Mar 5, 2005 10:36 AM
77460f150
Jul 17, 2004 07:59 AM
red3fidy
Feb 25, 2004 02:11 PM
