CURT Trailer Hitch Electric Plug conector
Old Feb 25, 2019 | 02:44 PM
Lillith's Avatar
Lillith
Hello Guys,
today we have mounted our towbar from CURT. Unfortunately, we are missing the right plug from the existing socket on the vehicle. I was looking for Rockauto but there are so many different ones that I do not know which one we need. We have a 7-Way RV Blade Style Adapter and a small 4-Way Flat Connector if I understand it correctly. Do you have an idea which adapter you have to order to make it work? I would put a photo in but I donˋt know how it works. We need a Adapter for Europe with 7 or 13 plugs.
Greetings from Germany
Lillith
Old Feb 25, 2019 | 11:17 PM
Sam I Am's Avatar
Sam I Am
Originally Posted by Lillith
Hello Guys,
Lillith
I'm not sure about ALL of Europe, but I know that some countries require separate amber turn signals on the rear of the vehicle. The American standard when Excursions were built is to use the same red lens on the rear for turn signal and brake light , same bulb 2 filaments.
I have no idea what the German lighting requirements are for a trailer, but if it is similar requirement to have separate brake & turn lenses then the circuits may be able to be joined and outputted from the rear vehicle lights to the lights for the trailer.
The American spec Excursion uses a separate circuit for the trailer lights, separate from the vehicle lights, and also a special dedicated circuit for the trailer brake control. I strongly recommend that you do not modify the trailer brake control circuit for safety reasons.
If your Excursion has already been modified with rear amber turn signals, then it may be a simple matter to tap into the vehicle light circuit, depending on the vehicle wiring standards for your country and/or any other EU countries you may drive through.
Has the Excursion been modified to use the amber turn signals?
If not, there is a tutorial on how to do that here:
https://www.ford-trucks.com/forums/1...llow-turn.html
It would help to know your Excursion's current status, and exactly what has already been done to modify the lighting,
and exactly which trailer connector it has,
and exactly which connector is on the trailer you plan to tow.
Old Feb 26, 2019 | 04:53 AM
Lillith's Avatar
Lillith
Thanks for the answer. the excursion is completely rebuilt for the european market. So he has extra orange turn signals in addition to the brake light. only the red blinkers in the mirrors are still there.
Old Feb 26, 2019 | 06:50 AM
Matt M, PA's Avatar
Matt M, PA
Great info from Sam. I converted mine to have amber turn signals in the back, but that conversion messed with the trailer wiring.
I don't know what's required in Germany for trailer lights...but the trailer feed from the Excursion may or may not supply what is needed. Perhaps that adapter that I mention in the link above may help.
Cor
All Things Towing
Dec 19, 2018 08:58 AM
Alloy
All Things Towing
Mar 15, 2018 10:44 PM
Myfreeford
May 3, 2012 10:13 PM
Danimal1481
May 17, 2009 09:07 AM
MustangMatt96GT
Mar 1, 2009 10:32 PM
