Change Remote Start Duration Time
Old Feb 20, 2019 | 09:11 PM
kd2dwj's Avatar
kd2dwj
Is there any way to extend the amount of time it will run on the facotory remote start? Either with forscan or another method, wanting to run it long enough that the engine begins to heat up before I take off in the morning
Old Feb 20, 2019 | 09:18 PM
h20camper's Avatar
h20camper
From the dash's IPC. Settings --> Vehicle --> Remote Start --> Duration. Its in the Owner's Manual.
Old Feb 20, 2019 | 09:39 PM
kd2dwj's Avatar
kd2dwj
thank you but I was looking for something longer then 15 minutes
Old Feb 20, 2019 | 09:51 PM
h20camper's Avatar
h20camper
Ah. Double pulse the key. Its in the manual too.
Extending the Engine Running Time
To extend the engine running time duration
of your vehicle during remote start, repeat
steps 1 and 2 while the engine is running.
If the duration is set to 10 minutes, the
duration extends by another 10 minutes.
For example, if your vehicle had been
running from the first remote start for 5
minutes, your vehicle continues to run now
for a total of 20 minutes. You can extend
the remote start up to a maximum of 35 minutes.
Old Feb 20, 2019 | 10:29 PM
fortheford's Avatar
fortheford
Use the Ford app on your smartphone. You can add time once engine is started.
RSVhack
Jul 17, 2016 07:58 PM
Pwrgeek
Nov 17, 2015 04:58 AM
Native Tex
6.7L Power Stroke Diesel
26
Nov 28, 2012 08:46 AM
fordboy_52
Kansas Chapter
Mar 29, 2010 01:07 AM
makomaker
Apr 29, 2008 07:20 AM
