Installing a 5th wheel hitch
Old Feb 20, 2019 | 03:21 PM
flyingtexan's Avatar
flyingtexan
Greetings,
I just bought a 99 F350 7.3 longbed dually which had a Reese hitch in it at one time. Long story short the guy removed the hitch for whatever reason but included it with the truck, so I need to reinstall it. My question is how hard it installing one of these and are there any instructional videos out there on how to do it?
Thanks
Old Feb 20, 2019 | 03:40 PM
Army RET's Avatar
Army RET
Without knowing (or seeing) more it's hard to say but I think you'd simply match the pieces to the appropriate spot and bolt it/ them in place.
If you're lucky then he left the lower plates mounted to the truck frame and you only have to reattach the "uppper" pieces.
Google - Reese or Youtube - you will likely find some links/ pics/ videos.
Old Feb 20, 2019 | 04:31 PM
flyingtexan
Yep all the L brackets are still in the frame, so yes I have all pieces, so sounds like I just need to bolt it up.
Old Feb 20, 2019 | 05:24 PM
kgburns's Avatar
kgburns
The 5/8" bolts going through the rails and L brackets should be tightened to 125-160 ft lbs, the 1/2" bolts going through the frame should be at 75 ft lbs.
Old Feb 20, 2019 | 06:13 PM
69cj's Avatar
69cj
Make sure you use Grade 8 bolts and nuts.
Old Feb 21, 2019 | 11:05 AM
flyingtexan
Reese uses grade 5 in their kit, and the tech line stated to use grade 5. Please educate me if you have information to the contrary. Thanks.
Old Feb 21, 2019 | 01:51 PM
kgburns's Avatar
kgburns
It's been awhile since I installed a standard rail hitch, but I do remember that all the bolts were grade 5. Consensus back then was that anything harder would shear off under stress, a grade 5 would give just a bit.
Old Feb 21, 2019 | 03:47 PM
69cj's Avatar
69cj
Just personal preference. If you have to buy them the difference isn't much for the extra strength.
Old Feb 21, 2019 | 07:58 PM
mptjelgin's Avatar
mptjelgin
Grade 5 bolts are plenty strong for mounting a hitch.
Old Feb 24, 2019 | 10:53 AM
mwheue's Avatar
mwheue
Go to www.etrailer.com and look up your truck and hitch. They have links on their product pages to PDF installation instructions in most cases.
Old Feb 24, 2019 | 07:56 PM
P.Bronner's Avatar
P.Bronner
When doing rail installations, I always use 5/8" carriage bolts, grade 5 or higher. It makes for a neater appearance and you don't need a second set of hands to hold the wrench topside. Did the previous owner leave you the 5/16" filler plates to prevent crushing the corrugations in the bed?
pacecar1979
Dec 9, 2009 04:52 PM
TexasGuy001
Nov 25, 2006 08:27 AM
Vinford
All Things Towing
Apr 22, 2006 12:16 AM
LWJ
All Things Towing
Jan 28, 2004 03:52 PM
kmac556
1997 - 2003 F150
Jun 1, 2001 09:51 AM
