How many bolts..........
Old Apr 15, 2006 | 07:39 PM
Vinford's Avatar
Vinford
I just installed a 5th wheel hitch in my 02.
On the brackets that go to the frame I only put one bolt in.
Is that enough?
I looked at my neighbours Chev and it has a dealer installed hitch with only one bolt in each bracket to the frame.
So theres 3 bolts on each slider rail going through the bed/box into the brackets on the frame, which have 1 bolt in each of them.
Only 1 hole lined up thats why I did it that way?
It looks as strong as the little pin that holds the whole 5th wheel table on top of the hitch.
Old Apr 15, 2006 | 10:55 PM
001-F DORF's Avatar
001-F DORF
What does the manufacturer say? It's best to follow their recomendations. What hitch do you have? Looks aren't everything.
Dorf
Old Apr 16, 2006 | 08:56 PM
Vinford's Avatar
Vinford
I dont have any specs on bolting it down.
I used universal brackets which have 3 holes in them but from any Ive looked at they dont put 3 bolts in each bracket?
Its a major job to put more bolts in plus Id have to drill a bunch of holes in my frame.
Old Apr 16, 2006 | 09:16 PM
BareBones's Avatar
BareBones
Does the manufacturer have a web site? Send them an e-mail, you might get lucky.
Old Apr 17, 2006 | 09:52 AM
001-F DORF's Avatar
001-F DORF
Try to put at least two bolts in the frame web for each bracket. My brackets have no bolts, they are welded.
Dorf
Old Apr 17, 2006 | 11:54 AM
Vinford's Avatar
Vinford
Welded to the frame?
I think thats illegal here.
Old Apr 17, 2006 | 02:48 PM
001-F DORF's Avatar
001-F DORF
It's approved by the manufacturer of my Draw-Tite and two of the brackets are also welded to the B&W Turn-over GN hitch brackets. Not used in a commercial application.
Dorf
Old Apr 17, 2006 | 06:12 PM
FastDEW's Avatar
FastDEW
My brackets are welded to the frame also. The dealer did the install.
Old Apr 20, 2006 | 08:06 PM
5_labsownus's Avatar
5_labsownus
My gooseneck hitch has 2, 3/4 inch bolts and 1, 1/2 inch on eash side and it is 30,000 # hitch. My friend has the same hitch in his chevy and it only has 2, 5/8 bolts on each side!
Old Apr 21, 2006 | 03:16 PM
AZDesertRat's Avatar
AZDesertRat
You didn't say but if your truck is a F150 these work great. No drilling because it uses existing holes in the frame. I wish I had one of these when I ruined 3 drill bits on my 98 frame. I just installed one of these on my 06 F150 and it was a walk in the park compared to last time!
http://www.etrailer.com/Merchant2/me...uct_Code=50042
Old Apr 21, 2006 | 10:12 PM
Vinford's Avatar
Vinford
Its a F-350
Old Apr 22, 2006 | 12:16 AM
partsman01's Avatar
partsman01
Hope this helps
Hope this helps
monsterbaby
All Things Towing
Jan 4, 2016 06:23 PM
duallycrew
May 22, 2014 09:19 PM
r___r
All Things Towing
34
Mar 29, 2014 01:10 AM
davzog
All Things Towing
Mar 30, 2006 03:48 PM
SoTX yellow
May 19, 2004 09:49 PM
