There is a grey connector under and to the left of the radio.
It is 6 pins, 2 X 3 configuration and should be stuck into a vertical metal piece with a plastic push rivet.
It has been a while since I accessed it, but I believe you can reach it by removing the access panel under the steering column in front of the drivers knees. Get in on the passenger side, lay across the console or center seat, look inside that panel back toward the passenger side.
