remote battery kill switch circuit
Old Feb 16, 2019 | 11:46 AM
hooler1's Avatar
hooler1
If your wiring is O.E. stock, I could see your concerns as over time the insulation gets brittle and breaks off. And there is not a lot that is fused with the stock wiring harness. But if your wiring harness has been changed with a fuse block added, and its physically in good shape then I would worry much less, as a fault should open up a fuse. Just my opinion.
Old Feb 16, 2019 | 02:57 PM
FuzzFace2's Avatar
FuzzFace2
I got to ask if the battery goes dead how do you get into the truck?
You say you have to keep some things powered so you can get it?
Even with the need to power up things kill power to full truck like someone said with the keyed switch on the NEG side and take key with you.
Even with the battery mounted under the floor just extend the cables to reach where ever you place the kill switch.
Dave ----
Old Feb 16, 2019 | 03:55 PM
jniolon's Avatar
jniolon
old and in the way
Hooler, wiring is new painless system (although that name is misleading) and most everything is fused
FF2,,,, battery dead ? emergency pull cable from left fender well to solenoid in the door.
well, ya'll are turning me away from my idea and looking into the single disconnect in the negative cable but that gives me more to worry on. The truck is low and if I keep the cables as short as I want, switch location is going to be a problem.
The running boards are about 6" off the ground...maybe 8" which means kneeling down or lying down to actuate it. Add to that 71 birthdays. Gotta get creative with my placement I guess. That was one of the reasons for the remote operated switch... I could put the switch somewhere convenient for me.. Just more to think about and I guess keeping the brain active is a good thing.
Started engine today and found another ''opportunity" for thinking. Carb leaking fuel down thru venturies... so I got that to think about too. But that's another thread.
thanks for all the ideas and info... it's good to be nice to old people.
john
j
Old Feb 16, 2019 | 05:41 PM
hooler1's Avatar
hooler1
I have been struggling with this idea too. I have a 56 and the OE original wiring harness still, so I disconnect the battery when I garage it. I have rebuilt a lot of the wiring but one of these days I plan to do the same as you and will go with Painless.
About the carburetor. Sounds like maybe some trash holding the needle and seat open thus flooding out the carburetor. Or a drowned float that has pin holes in it.
Old May 13, 2021 | 07:22 PM
EBEAR's Avatar
EBEAR
Sales have their own section .
Moderator note: This comment was in reply to a now removed spam post.
GrislteStick
Jul 20, 2017 11:31 PM
sunbelt57
Jun 16, 2015 09:25 AM
xminust
Apr 9, 2004 03:48 PM
vangion
1983 - 2012 Ranger & B-Series
Apr 4, 2004 08:54 PM
mrit
Electrical Systems/Wiring
Aug 15, 2003 09:10 PM
