Remote Starter Switch
Old Aug 15, 2003 | 12:13 AM
mrit's Avatar
mrit
I bought a cheap remote starter switch and am wondering what I am supposed to connect the positive and negative clips onto. Ive never used one before and the one didnt come with instructions.
Old Aug 15, 2003 | 06:52 AM
HomerWinzlow's Avatar
HomerWinzlow
If it has a remote mounted starter relay on the fender well or firewall you can just connect each lead to one of the two large posts on the relay. If it doesnt have the relay you can connect to the small "S" terminal of the starter and the positive battery cable. If you are just bumping the engine over leave the key off so it wont start the engine. Always use safety using a remote starter, like ensuring the transmission is in neutral, using chock block on the wheels, park brake set. Many techs have been injured or killed by starting an engine remotely when in gear.
Old Aug 15, 2003 | 09:10 PM
Franklin2's Avatar
Franklin2
Hook one lead at point #3 and the other at point #5.
dougsbart
Aug 20, 2013 07:16 AM
tim051
Aug 7, 2013 05:38 PM
Firefighter 1406
Jan 21, 2013 09:20 AM
shorebird
General Automotive Discussion
15
Jan 19, 2012 03:54 PM
boeing777
Jan 29, 2009 07:50 AM
