00 v8 ecm replacement
Old Feb 13, 2019 | 07:58 AM
bigcrunch's Avatar
bigcrunch
Has anyone here actually replaced a V8 ECM with one from a JY? I found a 99 get the ecm, key and ??
Old Feb 13, 2019 | 01:23 PM
shorod's Avatar
shorod
What issue are you trying to solve with a different ECM? Unless you're absolutely positive the ECM is the issue, adding such a significant variable could really increase your troubleshooting effort.
In addition to the ECM you would also need the PATS module with the ignition key and key cylinder as the anti-theft is married to the ECM and VIN. The PATS module is more than just the key. I'm not certain whether or not the instrument cluster in the 2000 is also married to the ECM or not.
-Rod
khadma
1997 - 2003 F150
Mar 31, 2013 11:34 PM
TJ Shaw
13
May 26, 2007 05:58 PM
estalder
Jul 5, 2004 09:45 PM
Doorgunner808
1997 - 2003 F150
Mar 12, 2004 09:04 PM
Vin_Man
1997 - 2003 F150
Dec 1, 2003 11:56 PM
