Possible purchase 2005 king ranch
Old Oct 8, 2019 | 07:57 AM
Onemoreblessedtexan's Avatar
Onemoreblessedtexan
So I might have screwed up. I decided to take off the cams to clean them and make the 24 roller follower and 24 lash adjuster replacement easier. I loosened the cam tower caps then took off phasers with engine key way at 11 o'clock (driver side cam spun a little but hopefully no harm done). Now that everything is clean and cams are back in place with towers still loose where do I go from here?
I'm thinking to use otc tool 6681 to tighten phasers bolt.
Take off cam caps and set cams in the correct lobed position then put caps back loose.
If cams are loose all valves are closed?? so I should be able to spin crankshaft clockwise until the key way is at 6 o'clock position.
Fit chains according to marks.
QUESTION: after chains fitted but guide tensioner not installed should I spin crankshaft key way back to 11 o'clock before tightening down the cam caps?? When is it safe to tighten down cam caps is my question, I can't even find the answer with Ford Makuloco haha. Thanks fellers!
Bainboy92
2004 - 2008 F150
23
Oct 29, 2025 01:16 PM
Jim_Rockford
Jul 12, 2020 01:01 PM
TheMaker2K
2004 - 2008 F150
Mar 21, 2019 10:36 AM
flyboy2610
Feb 22, 2019 09:22 PM
Forest_54_Ford
Aug 26, 2012 08:56 PM
