studs and gaskets
Old Feb 23, 2019 | 02:49 PM
  #46
69 Crewcab's Avatar
69 Crewcab
I am very glad i decided to go all the way in. On the bottom side the front lower main was well worn. Im not sure how much longer it would have made it , but it would have terrible to do a bunch of top side work and then ?? thousand miles later have the bottom end start knocking.
Old Feb 23, 2019 | 02:55 PM
  #47
69 Crewcab's Avatar
69 Crewcab
The rest of the lower main shells were worn but none as bad as that one. On the top side when I inspected each of the bores most had nice cross hatch but 3 didn't look good. I may have been getting some water migration into the bore. There was rust colored staining and the hatch was worn off.
Old Feb 23, 2019 | 02:57 PM
  #48
69 Crewcab's Avatar
69 Crewcab
Does any one have experience with this ? Can I get by with a ball honing and re-ring or should I go ahead and get it bored ? I have not measured it yet.
Old Feb 23, 2019 | 09:37 PM
  #49
TooManyToys.'s Avatar
TooManyToys.
I would dress it out with Scotch-Brite 96 (600 grit) which would clear the surface without interfering with the honed oil retention crosshatch. Then determine the pitting.
International calls out the hone for deglazing for new rings, but I found another source.
4 1/4" Flex-Hone tool silicon carbide 120 grit (108mm) <br>Commercial Grade
Old Feb 27, 2019 | 05:45 AM
  #50
69 Crewcab's Avatar
69 Crewcab
Jack
Thanks for the info. After some contemplation I decided to go all the way. What started as gaskets and head studs has gone to a full rebuild. New O-ringed heads from power stroke products , rings and bearings and pistons are the same cost wether they are standard or 20 over. We plan on keeping our excursion for at least 10 more years so we decided to do it all and have a dependable ride for years to come.
Old Feb 27, 2019 | 07:51 AM
  #51
HTM101's Avatar
HTM101
Originally Posted by 69 Crewcab
Jack
I'd do exactly the same, after looking at your photos.
Old Feb 27, 2019 | 08:04 AM
  #52
TooManyToys.
Go for it. If you have a good machine shop that your confident in, the block can be worked up. If any questions, Asheville’s option for a short block is another possibility from what I’ve seen. No matter what I do my trucks body won’t make 10 years, wish it was.
Old Feb 27, 2019 | 12:06 PM
  #53
m54sam's Avatar
m54sam
Originally Posted by bismic
Failure mechanism in the 03-04 HPOP's - and possible "fix":
http://bbs.homeshopmachinist.net/thr...fix-(continued
https://www.ford-trucks.com/forums/1...and-a-fix.html
Stock capacity Adrenaline is $1000 ($400 ish over OEM), not $1300. $1300 is for quite a bit more horsepower.
https://www.dieselsite.com/2003-2004...lpumphpop.aspx
Mind just...blown, that guys is a superhero with a mill. Pretty awesome reading thru the process. Thanks for linking that Mark!
genscripter
106
May 22, 2016 10:24 AM
Kane96
Apr 8, 2016 07:42 PM
mlytc
Apr 3, 2014 05:36 AM
HunerdProof1371
Nov 1, 2012 12:08 PM
Intheworks
Jul 8, 2011 09:21 AM
