We built a heavy duty motor stand which bolts to the motor at the motor mount location and allows you to easily rotate your engine pivot can clamp to lock motor in place
worm gear boat winch to rotate motor
another view of worm gear with a can of motivation
pivot for motor mount plate There will be different plates for my 428 CJ
one of the motor mount plates they are different on each side
When I go back together I will be using O-ringed heads from PowerStroke Products. Their own brand new heavier castings , which are cheaper than having UCF rebuilt heads. I was skeptical but I went out and saw their products and talked to Steve and Alex . Super nice guys , they showed me around and showed me how there heads were better. I would definitely recommend them. Apparently they are even suppling their raw castings to other shops to which re-brand them.
