223 fuel pump difference
Old Feb 5, 2019 | 08:29 AM
robski_1970's Avatar
robski_1970
I was looking through a parts catalog and found that there are two different types of fuel pumps for the 223 with electric wipers and with vacuum wipers. I have a 59 with a 223 and stock vacuum wipers. I have an electric wiper motor that I plan on replacing. What is the difference?
Old Feb 5, 2019 | 08:37 AM
hiball3985's Avatar
hiball3985
The one for vacuum wipers is a dual diaphragm to add more vacuum for the wipers. Electric wiper model uses a single diaphragm.
Old Feb 5, 2019 | 08:39 AM
Tedster9's Avatar
Tedster9
The fuel pump is tasked to provide vacuum for the wipers when so equipped. With electric wipers the extra port isn't needed.
Old Feb 5, 2019 | 08:42 AM
robski_1970
Would I be able to still use my existing pump with the electric wipers? I'm guessing so.
Old Feb 5, 2019 | 09:10 AM
Tedster9's Avatar
Tedster9
To be honest I'm not sure, but I don't see why not. Might need to install a NPT plug in the unused port? To keep out debris. Here's where I hector you to check the fuel pump pressure output though regardless. The last new pump I bought put out 8.5 psi and trashed the viton rubber needle tip in the carburetor. Stock pressure is 5 psi or so. Make sure they don't sell you junk, make sure what's installed now is serviceable.
Old Feb 5, 2019 | 09:17 AM
robski_1970
I don't have a good picture of my existing pump and I don't have my truck with me at the moment but as far as I can tell that its the original glass bowl type.
I plan on rebuilding it and I'll be sure to cap the port. Thanks for the fuel pressure notes!
Old Feb 5, 2019 | 09:23 AM
robski_1970
Actually, I DO have pic! (My truck is still a long way from being finished)
Old Feb 5, 2019 | 09:44 AM
hiball3985's Avatar
hiball3985
Your picture is a single diaphragm type.
Old Feb 5, 2019 | 11:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B9A-9350-B (replaced B8A-9350-F) is a fuel and vacuum pump for 1958/60 F100/600 223.
The two other pictured pumps were not used with 223's. 223 cancelled at the end of the 1964 model run, replaced in 1965 with 240 & 300 I-6's
Old Feb 5, 2019 | 12:21 PM
robski_1970
Thanks everyone for the replies!
tip49
30
Apr 11, 2016 08:22 PM
52' fordnut
Jun 20, 2015 10:12 AM
2pazr
Feb 20, 2009 09:45 PM
stevef100
Feb 13, 2009 05:58 PM
tp
Oct 23, 2004 07:18 PM
