ford 351m problems
Old Feb 2, 2019 | 07:57 PM
wyattharby1's Avatar
wyattharby1
4wd High
ford 351m problems
Hey, I'm 16 and new to FTE I've read a lot on here though. So, I'm 16 my first truck is what I've wanted since I was probably 10. its a 79 f350 4x4/w the 351m we picked it up from a family member. got it going pretty easy new fuel pump, accelerator pump, and she was running great by what I could tell would start at the turn of the key. it was running good and when I was driving it, it just died. now it will only idle and when I give it gas she dies. any ideas I was thinking maybe fuel starvation. any help will be appreciated.
Old Feb 2, 2019 | 08:16 PM
Justinb1984's Avatar
Justinb1984
Yes a fuel starvation problem could show itself that way. There may be a fuel filter threaded onto the carburetor where the fuel line connects. Best way would be to put a T- connector on the fuel line and use a fuel pressure gauge to see what’s happening when you step on the throttle.
If that checks out, I would probably start looking at the carburetor. Maybe rebuild or replace it.
Old Feb 2, 2019 | 08:17 PM
SDDL-UP's Avatar
SDDL-UP
Wyatt,
I think you're on the right track! Get yourself a see-through fuel filter and replace whatever you have now. You may have a bunch of crud in the system if it's been sitting a ong time. Good luck and WELCOME to FTE - great bunch of people around here.
Old Feb 2, 2019 | 09:07 PM
BeauF0RD's Avatar
BeauF0RD
Yes, a piece of crud could have gotten stuck in your needle valve, I had the same symptoms when a piece of crud got stuck in my needle valve in the front bowl of my Holley 4 barrel.
Old Feb 8, 2019 | 09:33 PM
wyattharby1
4wd High
thanks for all the help, yes there's crud in the gas tank sending unit was all rusty sat with very little gas in it im guessing, i cut all the stuff off the sending unit and just put a peice of hose on the pick up. i do have some questions of the brakes getting locked up
Old Feb 9, 2019 | 08:08 AM
smle's Avatar
smle
First welcome to FTE. From what you wrote about just putting a hose on your sending unit, bad idea. The tank needs to be dropped and cleaned out. You have a fuel strainer on the end of the sending unit. You're going to be getting that crud up to your carb. We don't want the problems that can cause.
ajzalesx
Sep 5, 2015 05:13 AM
wlittle
Jun 15, 2014 10:51 AM
RDS0130
Apr 12, 2013 09:32 AM
1977F1504X4AUBURN
Mar 2, 2011 01:40 AM
rockbronc1
Jul 31, 2004 07:41 AM
