st..st..stutering problem (vapor lock?)HELP!
Old Jul 30, 2004 | 11:11 PM
rockbronc1's Avatar
rockbronc1
Angry st..st..stutering problem (vapor lock?)HELP!
I've got a 78 F-250 w/ a 400. I replaced the fuel pump with a carter or mr gasket about two years ago. The problem is this. After running a while and turning the truck off aprox 10 min, when you start up again it idles normally until you start to load the engine, then it starts coughing like it's out of fuel. The same thing happens if it idles to long, you can watch the fuel psi go from 6 all the way to 1 in about three minutes, any suggestions? I've heard of people putting an electric pump after the switcher valve and turning it on when it starts surging, but I'd lke to do something I wouldn't have to explain to my wife every time she drives it... a little more permanent. My only thought is the fuel is staying in the pump to long at idle allowing it to boil and vaporize, how about a bypass regulator routed back into the fuel line at the switcher valve to keep fuel flowing. Any suggestions are greatly appreciated!
Old Jul 30, 2004 | 11:51 PM
Mil1ion's Avatar
Mil1ion
This isn't specific to the 73-79 truck.
I'll move this to the fuel delivery forum so those pro's can help sort it out.
Old Jul 31, 2004 | 07:41 AM
dlister's Avatar
dlister
I don't know if this will help I had a 79 that had an exhaust leak blowing exhaust on the fuel line and causing similar problems.
zuczis
Feb 11, 2017 01:59 PM
1956_F100
20
Apr 25, 2016 06:57 AM
Tyler S
Jun 23, 2015 10:54 PM
ejmaso
1947 and Older Ford Trucks
31
Oct 16, 2012 09:57 AM
batmmannn
Jul 30, 2010 07:09 PM
