So you're saying I can take the one out of my 92 and put it in my 93 even tho the gauges aren't in the same locations?
I have a bad something on my 93's speedometer. every once in a while the needle don't move, or gets pegged at the farthest right and the digital display isn't there. I can tap on the face on it and the needle and the numbers will work again.
Yes, the cluster is modular, so you can swap your speedo into the cluster with a tach, and retain your mileage. Once you remove the cluster, all the gauge pairs can just be popped out individually, makes a lot of sense when you're doing it.
What year is your truck? You need to stay within 92-93, 94-95, and 96.
What is the official reason for this? I did get a 93 (I pulled from salvage) unit installed in my 92, transferred the PSOM and cleared the gauges for white LEDs but I remember a person on Facebook market place argued the year did not matter. Were the pig tails different or internal circuitry. I am curious if I can collect additional PSOM boards.
The circuit on the backside is wired a little differently on the '94-'95 when compared to the '92-'93, here they are side by side.
There are wiring differences between the different cluster of years. You can use a cluster from different groupings, but you need to know what the plug/pin wiring differences are to make it work properly.
