Engine Swap
Old Feb 4, 2019 | 02:13 PM
92XLTF150's Avatar
92XLTF150
Question Engine Swap
Hello,
I am doing research, for my 1992 F-150 5.0 XLT, in an attempt to learn and apply as much information as possible to the restoration of my first truck. I am 100% an amateur and there is a lot of things I do not know/understand about the technical side of automotive repair/engineering. I purchased a crate engine, or at least I think that is what it's called, and installed it but never could get it running. It has sat for about 2 years now and I want to revisit it this summer. With all that being said here is my question.
-Does anyone have any tips or lessons they learned the hard way that I should keep in mind?
-Where should I start?
Additional info:
--fuel Injected
--It has been so long I can't remember who I purchased the motor from. It was online and they delivered through FedEx freight.
--When I turned the key it did not engage started (I think) again it has been 2 years since I've worked on it.
Any insight would be appreciated, thank you.
Old Feb 4, 2019 | 03:14 PM
EllieMae94's Avatar
EllieMae94
Hi,
Lots of knowledgeable people on here are more than willing to help. We're gonna need a lot more information, first. Who did you purchase the crate engine from? Fuel injected or carbureted? What was it doing/not doing? Did you check for fuel, spark? Timing? What modifications were done, if any? Did you try contacting the seller/manufacturer of this engine?
trucker11067
1983 - 2012 Ranger & B-Series
Sep 18, 2010 08:33 AM
luthrobediesel
Jan 27, 2010 09:57 AM
williamm21
Sep 20, 2008 04:21 PM
351ballsofford
Engine Swaps
Mar 6, 2005 06:07 PM
ford racer 02
Dec 21, 2001 10:25 AM
