CEL bonanza
Old Feb 1, 2019 | 12:15 PM
Dogdare's Avatar
Dogdare
Red face CEL bonanza
So, I had some issues with my battery terminal clamps just not being very secure anymore, so I decided to replace all my battery cables (positive and negative). Kind of a PITA, but nothing too bad. Since then, I've hit the motherload of glow plug related CELs, one for each glow plug, P0671 through P0678.
I've never had any glow plug issues, let alone 8 glow plug issues, so no doubt I'm at fault for having forgotten to reconnect a power cable for the GPCM. Where does the GPCM get its 12V from? Is it at the starter relay? I thought I was diligent in paying attention to every cable I disconnected so that I'd know where it went when reconnecting, but spacing the project out over two weekends clearly didn't help. Yes, I'm an idiot.
thanks,
Herb
Old Feb 1, 2019 | 01:37 PM
projectSHO89's Avatar
projectSHO89
California or non-California emissions? Check sticker underside of hood. There are significant differences in the glow plug control circuits between the two. California uses the module while non-California uses a simper relay.
Old Feb 1, 2019 | 01:55 PM
Dogdare's Avatar
Dogdare
CA compliant, but for what its worth, I think all Excursions were CA compliant. Just one of the weird things Ford did with Excursions compared to the F series.
herb
Old Feb 1, 2019 | 03:07 PM
projectSHO89
Okay, I seem to recall hearing that before. I'm just going off the documentation in the EVTM and it shows two variants.
Don't know if it's mechanically possible (the connectors look to be physically the same in the EVTM), but can one hook the two connectors to the GPCM backwards?
Old Feb 1, 2019 | 03:34 PM
Dogdare's Avatar
Dogdare
When I was replacing my positive and negative battery cables, I didn't touch or disconnect any of the GPCM connectors.
Herb
Old Feb 1, 2019 | 05:06 PM
dangrus's Avatar
dangrus
I was researching what people have done for upgraded battery cables and I ran across a thread referencing something hooked up for diesels. I didn't bookmark the thread because mine is gas. But, the guy had another cable that I didn't have to the top of the engine for the pump or glow plugs. Hope that helps.....
Old Feb 1, 2019 | 06:12 PM
projectSHO89
Did you hook all the smaller wires back up to the correct terminal on the starter relay, assuming you replaced that cable to the battery(ies)? Two of those wires are fuse links that feed the ALWAYS HOT power to the GPCM on pin 3 of both of the GPCM connectors.
That's the only connection I can see that might logically have been disturbed during a battery cable replacement.
Old Feb 1, 2019 | 07:36 PM
Dogdare's Avatar
Dogdare
Did you hook all the smaller wires back up to the correct terminal on the starter relay, assuming you replaced that cable to the battery(ies)?....
That's where I think I messed up. Shouldn't be too hard to figure out, but does anyone have a diagram of what cables go to what posts on the starter relay? That would help confirm things.
Herb
Old Feb 1, 2019 | 09:41 PM
projectSHO89
Well, all of the "little" wires (except the one that goes to the S terminal) have to go on the same post with the big red one that goes to the battery(ies). If any of them are on the relay stud with the other big wire that goes to the starter, then they're in the wrong spot and would only get power while cranking.
Old Feb 2, 2019 | 12:00 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
The GPCM is in the middle of the B+ wire that runs from the back of the alternator over to the relay on the fender. There is a tap off that 8 gauge wire to feed the GPCM. So, it gets power from the batteries when the truck is off, and the alternator takes over from the other side when the engine is running. The B+ wire comes off the alternator and joins the main engine harness going across the top of the engine, then pops out of the harness over the passenger side valve cover.
I agree with SHO...you hooked up the wires on the starter relay wrong most likely.
Old Feb 26, 2019 | 07:08 PM
Dogdare's Avatar
Dogdare
Yep, missed the smaller wire to the starter relay. All good now (well except for the new leak spraying fuel all over the underside of my hood).
Herb
mcali2
38
Sep 22, 2018 04:27 PM
Walleye Hunter
Apr 9, 2016 08:39 AM
swimlvr591
Sep 6, 2010 12:49 AM
watermanh
Jan 3, 2006 09:24 PM
barebackjake
Sep 10, 2005 11:29 AM
